Hot Ground
Old Sep 10, 2006 | 08:06 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Hot Ground
Hello fellas I am in need of some feedback. I was fiddling wih my car( 87 2.8 ) and I have a unique problem. When engaging the ignition switch there is a ground wire that heats up. Its the short wire leading from the negative battery terminal that grounds to the firewall right beside it. Now I can do anything else and the wire never gets hot. I checked everything from top to bottom and all seems fine. Double checked the wires at the starter and it looks good.
Could really use some help with this 1.
Thanks in advance,
DerickAB
Old Sep 10, 2006 | 08:16 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
hook up a dvm to it & verify voltae & polarity
Old Sep 10, 2006 | 09:56 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Have you checked the negative battery cable where it connects to the engine?
Old Sep 10, 2006 | 10:28 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Sounds like the engine ground has gone bad. I'd replace the cable since it's super easy and gets rid of any problems with internal corrosion that you might have.
Old Sep 10, 2006 | 11:00 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Well I just put in a new battery and the ground is connected at the smog pump and block ( maybe I shoudl move it). I also replaced the ground cable and hot cable. The hot as you know is at the starter so I'm not sure whats backwards. So I will get out the dvm and get busy after work tomorrow.
Old Sep 11, 2006 | 01:45 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Check that main ground wire that bolts to the smog pump bracket. I had one come loose once and it wreaked all kinds of electrical havok!
Old Sep 11, 2006 | 07:49 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
OK! Moved the ground wire and put it to the frame and all is good there. No I'm not getting any oil pressure. If it isn't 1 thing its another i guess. Took off the valve covers and started up the engine andno oil is coming up top. When first turn of the key before ignition gague goes up then once the car starts drops back to 0. Should have left it alone when I had it running good but you know you are never done. Just don't want to have to put on a new oil pump since this one is only a few months old.
Old Sep 11, 2006 | 08:07 PM
Engine: 5.7 / 7.4
AMEN to that
verify w/aftermarket oil gauge, jsut incase, and maaybe even cheaper than alternative
Old Sep 11, 2006 | 09:48 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You'd better still hook up a good ground from the engine to the frame to get that starter current back to the battery easily. First your little ground strap to the firewall will burn and then...
87 and up 2.8s have high oil pressure well into the 200k mile range. What did you do to your engine?
Old Sep 11, 2006 | 10:45 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Just did a rebuild a few months back and everything was fine. Just couldn' t leave well enough alone. Pull a code her change a part there, you know the routine. Trust me when I get it right this time I'm not touching a d**n thing.
Old Sep 17, 2006 | 04:43 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Here is the wire that continues to get hot ( its the shinny copper wire) . Don't know what else to do. Just can't leave well enough alone. I guess its time to call in the pros b/c I'm done with it.
Old Sep 17, 2006 | 10:38 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
You have a bigger picture? I can't see what it is.
Old Sep 17, 2006 | 11:07 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
I'll have to get a better picture tomorrow but its the braided copper wire from the fire wall to the block at the rear of the engine.
Old Sep 18, 2006 | 12:21 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
If that's the ground that's getting hot, then you have one of 2 problems...either the ground from the body to the battery is bad(most likely cause) or the ground from the engine to the battery is bad. I would check the ground from the chassis to the battery and maybe even run a new one all together.
Old Sep 18, 2006 | 05:56 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
or there's a bear wire either against the body or engine. Ihad that problem too. it you were to take a normal test light and disconnect the battery and use the test light between the terminal and connecter, does it light up.....I did that to find the wire i busted puttin the dash back in
Old Sep 18, 2006 | 07:15 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
OK! Ground problem solved. I would guess that the ground cable I purchased was bad took it back to AZ and all is well now. No hot wires. As for the oil pressure issue, droppin the pan tomorrow and taking the oil pump back to Advanced. Sad thing is the warranty was up 5 days ago( only a year). Good thing is my buddy works there so hopefully he can do me right. Thats what I get for buying the parts ahead of time even b4 I thought of doing the rebuild. Its still in the computer so we'll c what happens. Half way there and then I'm leaving well enough alone.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
Glowsock
Sep 5, 2015 07:48 PM
