What V6's came with forged piston's from factory?
Old Sep 30, 2006 | 09:07 AM
firstfirebird's Avatar
Does anyone know what V6's came with forged pistons (3.1) in particular as I am building a twin turbo setup for my v6 and can't find solid info on it! Don't want to chang the pistons if I don't have to....Thanks!
Also will have pics soon on the one-off headers/turbo mount I'm building...
Old Sep 30, 2006 | 09:46 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
How many miles are on it. Ive heard that if you have a lot of miles its better to change them out...especially if youre running twins. I would change them just to be safe. Just my .
Old Sep 30, 2006 | 10:01 AM
89k
Old Sep 30, 2006 | 05:07 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
No OEM 660s were equipped with forged pistons. They are ALL cast.
Old Sep 30, 2006 | 05:22 PM
Should I use the fact. shaped pistons or go for dished for lower compression?
Old Sep 30, 2006 | 05:25 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
a lower compression would be the better choice, you can run more boost
Old Sep 30, 2006 | 06:48 PM
Then could I use closer-ratio rockers to get more lift - with dished piston I mean..?
Old Sep 30, 2006 | 08:30 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
if you get your came made for the setup, you shouldn't need higher ratio rockers
Old Oct 1, 2006 | 08:20 AM
Rockers are easier to install, and if looking for more lift, not duration...it's the way to go
Old Oct 2, 2006 | 11:11 AM
Theis myth of low static compression needed for forced induction meeds to be stopped.
A higher compression enegin is more efficiant, revs quicker, making it nicer to drive, oh and it would also spool the turbo quicker.
From personal experiance I will build a higher SCR engine over a lower one, even when boost is concerned.
I have an 8.9:1 SCR engine in my Jimmy now with a turbo, if or when I put it back together, I will be using thinner head gaskets to bump the SCR to 9.3:1. If I really wanted to, I'd get new pistons to bump it to 9.6:1, but I already have the thinner head gaskstes.
Old Oct 2, 2006 | 11:12 AM
More lift does not always mean more flow, sometimes more duration is what is needed.
Old Oct 2, 2006 | 11:13 AM
More lift does not always mean more flow, sometimes more duration will be leaps and bounds more than increased ratio rockers.
Old Oct 2, 2006 | 02:24 PM
Six_Shooter,
Have you done a cam swap with the motor in the car? The reason I'm going for forced induction is because I don't have the space to pull the motor in my garage now, otherwise I'd go with a V8, not to mention I like the idea of pulling away form a V8 with a 6. Thanx for the info on compression. When I do finally put forged pistons in, my plan is to have the heads worked @ Avalon Racing here in FL. First things first though, I'm ordering a turbo unit now and am building/designing some one-off headers for the 3.1. Have you dealt with a twin turbo set up before?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Nervous2
Oct 8, 2015 10:53 PM
BBSDesigns
Sep 22, 2015 03:08 PM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
