V-6 engine swap - questions?
Old Oct 24, 2006 | 06:01 PM
Reed35's Avatar
Car: 84 Trans Am
Transmission: TH350
My 82 camaro has the 2.8 v6 and the engine is shot. The trans is a 700-R4. I found a 4.3L V-6 that came from a 1985 caprice. I did some research and i found that the engine used the TH-400 tranny. I was wondering if the 700-R4 would bolt up to a 4.3, or will i need to find a used TH-400. Thanks for the help.
Old Oct 24, 2006 | 06:15 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
A v8 700R4 will bolt up, but not the 2.8 700R4. It uses a different bolt pattern. Good luck
Old Oct 24, 2006 | 11:04 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
are you sure it's a th400? no v6 that I know of ever had one of those stock behind them.
Old Oct 25, 2006 | 10:26 AM
Reed35's Avatar
Car: 84 Trans Am
Transmission: TH350
I'll do some more looking around. Thanks for the help guys.
Old Oct 25, 2006 | 11:24 AM
Reed35's Avatar
Car: 84 Trans Am
Transmission: TH350
I have a 82-92 camaro repair manual from Haynes. I looked up the transmission and it says the 700-R4 wasn't used until 1984. The tranny in my 82 berlinetta is supposedly a 200C. Is that right???
Old Oct 25, 2006 | 03:37 PM
Engine: 5.7 / 7.4
sounds right. is it a 3sp?
Old Oct 25, 2006 | 06:41 PM
Reed35's Avatar
Car: 84 Trans Am
Transmission: TH350
yeah, 3 spd.
Old Oct 25, 2006 | 10:35 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Some early 90's pickups came with the 4.3 and a 3l80. 3l80 was just a new name for the 400. Just like the 700r4 became the 4l60. I don't know if it came in the caprice or not. Mike
Old Oct 25, 2006 | 11:07 PM
firstfirebird's Avatar
I had a 1986 GMC pickup w/4.3L, TH400 trans, and a 4BBL carb. It went 298,000 miles before I got an oil leak on the highway and spun a bearing....
But to confirm the answer to your question the 700r4 has two bolt patterns. One for 60*, and one for 90* engines. Yours is a 60* and the 4.3 is a 90* engine. As the 4.3 is a "two short" or a 350 with two center cylinders missing.
Old Oct 28, 2006 | 09:27 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
Yep thats what it has. They are the worst trans. ever put in a car.
Old Oct 29, 2006 | 08:39 PM
Reed35's Avatar
Car: 84 Trans Am
Transmission: TH350
Why are they so bad. The only thing i have heard about them is that the 200C doesn't have a hydraulic clutch. Is there anything else?
Old Oct 30, 2006 | 03:38 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
I wouldn't exactly call them the worst trans ever considering that they were what buick was using in all of the T-types. If it can hold up to that power, its not too shabby
Old Oct 30, 2006 | 07:25 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
They are known for going out all the time and they are just plain weak. I thought they were okay trans. but after having my car for about a year I found out they are not the best, So if mine goes out I am dropping a 700R4 in it.
Read this link about the TH200c
Link
Old Oct 30, 2006 | 07:35 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I think it's the 3rd one on the right hand side and the 2nd one on the left that are missing...lol
So, the short answer to your question is no, the trans you have right now will not just bolt up.
Old Oct 31, 2006 | 08:02 AM
That's what I said, right?
The reason for telling reed35 about the "two short" is so he would know if he uses the 4.3, he could use a tranny from behind a V8, but good one!
Old Nov 3, 2006 | 09:50 AM
Reed35's Avatar
Car: 84 Trans Am
Transmission: TH350
K, i don't think that 4.3 will tear up my rearend, but will i need a new driveshaft?
Old Nov 3, 2006 | 12:51 PM
Shouldn't if your using the same tranny (700r4) as the trans cross member position doesn't change from v8's to v6's - correct me if I'm wrong guys.
Old Nov 3, 2006 | 11:00 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
I believe the crossmembers are the same...a friend of mine converted his V6 Camaro to a V8 with a TH350. He kept the V6 tranny crossmember and used a driveshaft from a TH200C-equipped car, and everything works like factory.
If you go from a 700R4 to a three-speed, you may need a new driveshaft for length reasons. If I remember correctly, the 200C(three speed) driveshaft is longer than the 700R4 one (overdrive). I have no idea how big the TH 400 is in comparison to the TH350 or 700R4, though...
Old Nov 4, 2006 | 08:28 AM
The 700r4 is the longest one, I'm pretty sure the th350 and 400 are the same, totally unsure bout the 200
Old Nov 9, 2006 | 11:22 AM
Reed35's Avatar
Car: 84 Trans Am
Transmission: TH350
k. thanks for the info.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
