custom intake : update pics
Is that the same intake you were working on before?
...when you had the mill set on KILL?!?!
Last edited by firstfirebird; Dec 15, 2006 at 06:08 PM. Reason: Automerged Doublepost
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I read that youre getting close to putting the 3.3 back together. I was just wondering if there are any update pics on the intake?
i have to take more pics,but it prolly wont be for another week or so,cause my gf is in the hospital right now,and has to stay there for atleast another week.
so i havent been going to work since ive been runnign back and forth,but if i do get to stop by the shop ill take a couple pics.
btw i had to lenghten the dizzy 2.5 inches for everything to fit the way i wanted it to.
btw it may be possible to use a stock gen 2 manifold with a custom upper plenum by just having the dizzy lenghtened.
making the dizzy longer is actually dam easy if u have the right tools to do it.
Transmission: 5-speed/T-5
I know it would be rather tight, if not through the cowl on my truck, and I know there isn't much more space on the F-body than I have.
if i remebr right i could go upto 3 inches extended without hitting anything,if i happened to have measured wrong i can still drop a stock hieght dizzy in.i lenghthend mine just to make it look better and to be a lil easier to access it should the need arise while the motor is in the car
Car: 91' Firebird
Engine: 3.1L V6
Axle/Gears: 3.23's
interesting point, as I know there is room to bring it up. any idea as to how much this would cost someone?
tj im not sure,depends on who does it i quess but id say prolly around 100$'s
anyways i got some more work done,the manifolds starting to take shape now,u should be able to picture what its onna look like from these pics,mind u the plenum isnt on the runners yet
Nice work dave! Can't wait to see more!
If the stock intake can handle 900hp(as well as flow some sick numbers), what's causing you to change it?
The funny this is the gen III (top end) stock has been shown to support well over 300 HP, some dyno numbers show 350ish HP and more in torque, with forced induction.
genIII FTW!
genIII FTW!
In stok unported form, with boost I've seen low 200s from genI.
GenII are quite a bit better and have seen upwards of 275 HP or so.
GenIII so far 365 dynoed wheel HP I believe was the last reading from a guy that has a turbo 3400 in a Cavalier.
What kind of boost were they running?
Car: 91 Camaro
Looks good. Just wondering how you are going to run the fuel rails. I assume custom...side to side mabye?
sorry for the crude drawing lol
but this should give u an idea
fuel rails down each side with legs connecting them to each injector
the rail will be connected by a crossover tube in the front
How are you keeping the volume of the runners perfectly equal?
Fast355
Dec 2, 2016 06:33 PM
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
