Simple Performance Upgrades?
Old Jan 15, 2007 | 02:16 AM
syko's Avatar
Hi all,
I have an Automatic 1989 Camaro RS 2.8L and I have a couple questions. What are some simple performance upgrades? I am not too mechanically inclined meaning it'll be very difficult to work with major engine upgrades like changing the cam or modding the piston heads...
If I change my stock air filters into K&N, how can I increase the airflow that passes through them? I read somewhere that you can drill 1/4" holes, but I forget exactly where you would drill those holes...
I also plan on putting a Flowmaster 80 Series single in/dual out muffler...
Any help would be appreciated. Thanks in advance.
Old Jan 15, 2007 | 07:36 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
look in the tech articles i believe, you can drill the holes in the boxes, or some of us have actually cut the bottom right off the box, it opens up the air flow more in the upper rpms. i guess it depends on where you live and if you plan on puddle jumping. i dont drive mine in the winter or even the rain much anymore so i dont have a problem. but even when i did drive it in the rain and snow, as long as i didnt go through any big puddles or anything i never had a problem w/ cutting the bottom of the air box off.
Old Jan 15, 2007 | 09:53 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
It's your best friend. This question has been asked a million times. There is plenty of info on this board, you just have to be willing to go out and find it.
Old Jan 15, 2007 | 01:25 PM
syko's Avatar
I did search! And it wouldn't load the message board... Guess there were too many threads on performance upgrades? Or my internets is broke...
Another question, my car is idling at ~1500rpm, and sometimes for reasons unknown, it slowly jumps up to 2000rpm... I don't think this is normal
Old Jan 15, 2007 | 05:35 PM
firstfirebird's Avatar
Sounds like you need to tune up before performing any modifications.
Welcome to the site, and I agree with 2.8boy - SEARCH. There are stickys at the top of the V6 page...
Old Jan 15, 2007 | 06:15 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Its not you. As much as I love this board, the info on it. The past year or so it has sadly slowed/bogged down that I dont come to it as much as I use to. The search feature is even worse!!
Anyway, just remove the air deflectors in your airbox if all your doing is daily driving it. Just throwing a muffler on it doesnt do near the performace of replacing the whole catback system. You wont spend to much more getting a whole boltin catback as if you would paying a shop to just install a new muffler.
Old Jan 15, 2007 | 06:28 PM
SageMoonblade's Avatar
The problem you will run into with the easy upgrades is that the power gains will be little to none depending on what you do. If the car isnt your daily driver your best bet will be to get a manual like a "Haynes" and learn as you go. Most people arnt certified mechanics, we learn by doing. If you think your in over your head send me what you want as far as HP and torque specs that you want and I'll get the parts lists together and tell you exactly how to do it.
Old Jan 15, 2007 | 06:40 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
You could do the coolant bypass mod, build scoops for your intake (if you have the one that draws in front of the radiator, or some other free mods that are to be found in the site somewhere.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Fronzizzle
Feb 9, 2017 09:31 AM
customblackbird
Oct 1, 2015 04:30 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
scottmoyer
Sep 7, 2015 07:06 PM
