EGR Valve
Old Jan 28, 2007 | 09:42 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
EGR Valve
My engine idle is slightly erratic and it dies sometimes at a light. I don't think that it is a vaccum leak somewhere else. I had the vaccem system worked on three months ago plus I sprayed carb cleaner everywhere to find one. The code just popped up yesterday. Is there a way to diagnose if it's the valve or solenoid?
Old Jan 28, 2007 | 07:31 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
try a search for EGR, i remember there being a diagnostic flow chart posted somewhere on here by someone a while ago. i think it was dean (he had lots of screen names) or possibly KED85. but i definetly remember it being posted a year or so back.
Old Jan 28, 2007 | 07:41 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Front page of thirdgen.org "Tech Articles" - "The lowdown on code 32 EGR" Will help understanding.
Problem could be vac leak, stuck open or closed valve, vac modulator (aka vac switch) - EGR solenoid, etc.
Vader posts a lot of flowcharts too, wouldn't be surprised if he has a 32 chart out there.
While your idling at a light your EGR valve is not supposed to open. Its only supposed to work at part throttle and the car is moving or when decellerating. So you could test it by pulling the vac line to it and plugging that vac line. If it doesn't stall - well there ya go, you've discovered that your car is opening your EGR valve at idle when it isn't supposed to. However if your EGR is stuck open, that won't tell you a thing. It also won't tell you if the EGR valve is somehow being blown open by exhaust.
Old Jan 28, 2007 | 08:08 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I went to the junkyard and got one that works. Mine wouldn't hold any sort of pressure but it still moved freely. The new one holds a vaccum fine. It was more like it wouldn't open when it was supposed to.
Did the search of the code and EGR and I didn't find much for it. Nothing that I was looking for.
Old Feb 4, 2007 | 01:32 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Light still comes up. Replaced the valve and solenoid, help?
Old Feb 4, 2007 | 02:06 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
did you ever clear it?
Old Feb 4, 2007 | 03:38 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I cleared the codes. It comes back on after 20 or so min of driving.
Old Feb 6, 2007 | 05:24 AM
drdave88's Avatar
Engine: 6.0L
could be a plugged vacuum line causing your problems. may wanna check that out, be careful not to snap them or youre in for more fun
Old Feb 6, 2007 | 06:53 AM
firstfirebird's Avatar
I get the same code, but that's probably because my EGR selenoid/valve and smog pump are laying on the side of the driveway, lol. It doesn't affect my driveability or seem to bother mileage, and the code only pops up once in a while (actually only when I jump the pins).
Old Feb 6, 2007 | 04:16 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
That's exactly it. It'shasn't come on in a couple of days. Only once in a while and doesn't afect diveability.
Old Feb 6, 2007 | 04:27 PM
Does your engine light go on, or are you jumping the pins to see the trouble codes?
Old Feb 7, 2007 | 09:27 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
The SES light comes on.
Old Feb 7, 2007 | 09:34 PM
Funny, mine came on today while driving for the first time since the smog/egr delete. Got home and saw 32. That's the least of my problems right now, pretty sure I have a broken valve spring.
EDIT: Good thing I have four other cars, lol.
Old Feb 7, 2007 | 09:40 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Well this is my only one so I don't need any major problems.
Old Feb 7, 2007 | 10:02 PM
I hear 'ya. Less than a year ago, I only had my work truck. When it was broke, not only did I have no transpo, but couldn't work either.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
