Cleaning the intake
Old Feb 7, 2007 | 03:07 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Cleaning the intake
What is the best way to clean the intake? More like how do I do it and what can I use without messing the engine up. I read somewhere that spraying carb cleaner into the throttle body will work fine but I'm not sure. Did a search and didn't really find anything. Thanks in advance.
Old Feb 7, 2007 | 03:14 PM
ghotachevy's Avatar
go get a can of throttle body cleaner and a soft brush
Old Feb 7, 2007 | 03:56 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Any way of doing it without taking the whole intake off? I know it sounds stupid but I guess that there is no way to spray cleaner in there while the engine is running?
Old Feb 7, 2007 | 04:15 PM
ghotachevy's Avatar
get a can of seafoam and read instructions bout 4 ways that stuff can be used
Old Feb 7, 2007 | 05:01 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
I 2nd the seafoam. good stuff.
Old Feb 7, 2007 | 05:26 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
seafoam,
Old Feb 7, 2007 | 07:18 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Ok thanks guys. I'm just trying to clean every system in my motor to free up HP and get better MPG. Just basic maintainence. Anyhting else I should do/check?
Old Feb 7, 2007 | 07:24 PM
ghotachevy's Avatar
t stat flush the radi hater
Old Feb 7, 2007 | 08:05 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
What about plugs and wires? Any recommendations?
Old Feb 7, 2007 | 08:29 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
oven cleaner and the local car wash works good
might take paint off the valve covers though, possibly
hell just the spray nozzle at the car wash cleans transmission and other parts real good without any chemicals at all, so...
good luck
Old Feb 7, 2007 | 10:25 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Get some nice Delco wires / plugs and a new distributer cap / rotor. You'll be amazed at the difference.
Old Feb 8, 2007 | 12:39 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
read up on the TomP tune up, and peruse the aftermarket parts for upgrades on things
Old Feb 9, 2007 | 05:28 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Where is that at I looked at the archives and nothing for a tune-up was there.
Old Feb 11, 2007 | 03:47 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Picked up the seafoam to clean the intake. Where is the best place to pour this in?
Old Feb 11, 2007 | 04:14 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
TomP Tune-Up
Old Feb 11, 2007 | 05:40 PM
ghotachevy's Avatar
id say suckit in a vacuum line is best
Old Feb 27, 2007 | 06:00 PM
bluecamaor3.1's Avatar
Car: 1991 Camaro RS
Engine: 3.1
Look at the brake booster on the drivers side firewall. There is a large vacuum hose that runs from it to the intake manifold. undo it from the brake booster and put a small funnel in the hose. Start engine and pour seafoam in slowly while engine runs. When can is empty, reconnect vacuum line and let engine idle. You will start to notice the car smoking really bad (that is what it is supposed to do....) after about 5 minutes idleing, run it to 2k rpm's for a minute or two and then let it idle until it stops smoking. Carbon cleaned from intake and valves!!!!
Old Feb 27, 2007 | 06:15 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Already tried the brake booster and the engine won't run with it unhooked. I got a spray bottle and put the whole thing through the throttle body and no difference in the carbon builup. It's pretty thick on the walls of the intake.
Old Feb 27, 2007 | 10:34 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
just take the intake off. its a very easy 20 minute take off... simple as cake. and if its old, go ahead and replace the gaskets (17.00 or so for a WHOLE intake and valve covers set of gaskets - felpro i think). i went ahead and got a whole pack of carb cleaner for the intake (8 pack). i just sprayed the crap out of it, painted it, smoothed down the surfaces and put the gaskets on and bolted it back up runs much better.
deracer
Apr 11, 2016 12:04 AM
Ducati900ss
Sep 2, 2015 09:05 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
