2.8/3.1 compatiblity question
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
will 2.8 headers work with the 3.1?
THESE------> http://store.summitracing.com/partde...5&autoview=sku
Transmission: 5-speed/T-5
Car: 1998 Camaro Z28
Engine: 6.0L
i remember hearing theyre 50 state legal, but only if you do not have AIR, because you have to delete the AIR pump. but i cant find where i read that.
Engine: 6.0L
Air Injection Reaction: it injects fresh air into the exhaust manifolds to help lower emissions by dropping your hydrocarbons and carbon monoxide levels. so if theyre shoving a sniffer up the tailpipe, theyre gonna find ya out. if you have one on your car, there will be pipes going into each port of your exhaust manifolds and a big pump on the lower pass side of your engine w/ 2 big rubber hoses on it. thats how youll know if youve got it or not.
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
There is a steel line going into the passenger manifold but not the driver side.
EDIT: Looking at the pictures of the headers, it looks like there is some sort of plug on the passenger side (on ceramic coated and black painted):
Does anyone know if these will work with a stock style cat. converter though? I just put a Magnaflow direct fit on.
EDIT 2: I was right, according to Pacesetter's web site, these headers have: Flanged Collector, Hook-ups for smog & engine management sensors, Comes with header extension to connect to stock system. Fabrication may be required, and 50 States legal.
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Hello. I have a question. How hard would it be to weld something on the header so the air pump would still be functional. The smog test they do here in my part of PA is a visual only. Meaning that all of the stuff has to be there and SEEM to be in working order. There is no sniffer test and they wouldn't scan the Computer because its not an OBD-II. But they scan all cars that are I belive, 1996 on. So my 91 would be fine on that.
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
And the plug on the passenger side that you mentioned is for the EGR.
Engine: 6.0L
its the big thing sticking off the top of your pass exhaust manifold w/ a metal tube that goes back to the intake manifold.
Car: 2012 Corvette
Engine: LS3
Ok, I thought that was the AIR pump. Where does that go into the manifold then? I didn't see anything else besides that.
Engine: 6.0L
if theres nothing else at all going to your exhaust manifolds, then you probably dont have AIR on your car, so you dont have to worry about it.
Car: 91 Camaro
Here is a pic. of the stock 3.1 pass. exhaust manifold.
The 3.1 only has one hole for the AIR pump, and it is not on the 2.8 headers.
Car: 2012 Corvette
Engine: LS3
I went back and looked and I didn't see EGR because of the alternator bracket and some metal piece covering the EGR tube that goes into the manifold. I have AIR and the EGR then. Damn.
Car: 89 2.8 RS
Engine: the 2.8
Transmission: 700r4 auto
Axle/Gears: stock one wheel squealer
just buying a new cat should allow you to pull the air system out of the car entirely if your local place doesnt do visual checks or if your mechanic is cool and will let it go.
