2.8 Dies after crank. need to fix today!
Old Feb 25, 2007 | 02:09 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
My car was running great this morning. I replaced the thermostat last weekend and it had a leak so I dug into the engine today and the car won't even stay cranked. It dies as soon as it cranks. It sounds like there is no gas but I know there is. I did not break any vaccum lines but that is what the problem sounds like as this has happened before (broke a couple of lines) but got it fixed Aug of last year. To get to the thermostat I had to take off the UIM, TB, and a couple of vaccum lines and sensors. Everything is hooked up to where it was and when I cranked it to go to town it did not want to stay cranked. If I give it some gas the engine will stay cranked only for another second or two.
Old Feb 25, 2007 | 02:20 PM
lilbanger's Avatar
Car: 91 firebird
Engine: 3.1L
Transmission: AT
sounds like my same problem....a lil...dont know what my problem is....
Old Feb 25, 2007 | 02:37 PM
lilbanger's Avatar
Car: 91 firebird
Engine: 3.1L
Transmission: AT
is it multiport or what?
Old Feb 25, 2007 | 02:43 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
89 2.8 MPFI
Old Feb 25, 2007 | 02:47 PM
lilbanger's Avatar
Car: 91 firebird
Engine: 3.1L
Transmission: AT
Originally Posted by 2.8RS
89 2.8 MPFI
same as mine.......a pain in the ****..........
Old Feb 25, 2007 | 02:56 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
For me its really confusing. Before I took the UIM and everyhing else apart the motor ran like a champ besides the high idle. Now it is utter crap. I broke somehting but I don't know what or where. I am clueless. I even too the UIM off again to make sure everything was connected and still together, and from what I can tell everything is hooked up. I'm **** for words right now.
Old Feb 25, 2007 | 03:19 PM
firstfirebird's Avatar
You checked everything? Like the MAP, vac lines, distributor vac adv, TB sensors, plugs in the dist, blue spark from the plugs, injector plugs, and when you took the UIM back off - how did the gaskets look?
Old Feb 25, 2007 | 03:22 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I never touched any of the ignition stuff at all. Everything is hooked up likie it should be. I'll get out there again and check it all.
Old Feb 25, 2007 | 04:46 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I fixed it. My TB gasket was out of wack. The bottom bolt missed the hole. I opened up the butterfly and low and behold there is the gasket.
Old Mar 2, 2007 | 08:03 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
Transmission: TH-700R4
try the distributor cap and asyl
mustangman65_79
Apr 14, 2017 05:37 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
spaigo
Aug 21, 2015 07:46 PM
bamaboy0323
Aug 15, 2015 07:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
