So i have a check Motor Light on.
Old Feb 26, 2007 | 01:37 PM
Berlinetta101's Avatar
Car: 04 Chevy Silverado 1500
Engine: V6
Axle/Gears: Stock
So i took it to the Auto Zone, and Got the Following Codes:
34-MAF, 45-02 Sensor(by the Caddy), 23-Carb
I would like to know what the 23 Code Means in detail, and does it mean i have to replace it?
Thanks,
Robert.
If this is the wrong forum, sorry. n00bish Mistake.
Old Feb 26, 2007 | 04:47 PM
Engine: V6
Axle/Gears: Stock
anyone care to help? Please
Old Feb 26, 2007 | 05:05 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
You got to give people a little more time to respond. Help will come soon. According to my Haynes manuel code 23 is your mixture control solenoid.
Old Feb 26, 2007 | 05:07 PM
Engine: V6
Axle/Gears: Stock
So that means it needs Replaced right.
Old Feb 26, 2007 | 05:13 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
replaced, repaired, may be a vacuum line to the car, or the fuel... it means there is something wrong. a sensor is back, the solenoid is bad, it isn't getting a good connection. a wire is messed up, whatever. if you change it and it doesn't go away... then it is a wire/vacuum line/etc. that goes with any sensor.
Old Feb 26, 2007 | 05:42 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Really it could be anything hooked up to the solenoid or the solenoid itself. If your motor is doing anything weird that can narrow down the issue. Details are a good thing. Someone around here might know something if you give symptoms.
Old Feb 26, 2007 | 05:44 PM
Engine: V6
Axle/Gears: Stock
I know when i put it in N, the car tends to idle high, and sometimes climbs up alittle, The water pump is making a rattleing noise, but my old 91 did the same thing, and never hurt it.
Old Feb 26, 2007 | 06:23 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Everyone's car idles higher in neutral or park.
Wade787b
Sep 29, 2015 01:15 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
