Intake Gasket, Pulling Pushrods
Old Jul 8, 2007 | 02:38 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Is there anyway to get the intake gaskets on and what not without pulling the pushrods?
My longblock came fully assembled, and I can't seem to find if there's anyway to put the intake gasket on without pulling the pushrods.
Old Jul 8, 2007 | 02:49 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Intake Gasket, Pulling Pushrods
You have to pull the pushrods to put intake gaskets on.
Old Jul 8, 2007 | 03:23 PM
Engine: 3.1
What I thought, but I figured hey, there might be a way around it, heh. Worth asking though.
Old Jul 8, 2007 | 03:31 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Just make sure that you adjust the pushrods right the first time.
Old Jul 8, 2007 | 04:26 PM
firstfirebird's Avatar
You said you swere still having ignition issues, though.
Pulling the pushrods is actually simple but like 2.8 said, it's adjusting the valves can be a pain if it's your first time.
Old Jul 8, 2007 | 04:43 PM
Engine: 3.1
It is my first time. Any tips or hints?
Old Jul 8, 2007 | 05:25 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Well I think that I have the ignition and valves right. Although my car threw codes for the O2 and ignition module. Now I think that one of the injectors is fried. The same cyl keeps on fouling plugs (see the new post in my problem thread)
Read this thread. It's me trying to figure out what is wrong with my car and figured out how to adjust my valves right. I think that every step is in there. If you have a haynes manuel then adjust the valves in the order is says. To figure out 0 lash read the thread and how much to tighten down.
https://www.thirdgen.org/forums/v6/4...like-crap.html
Old Jul 9, 2007 | 02:08 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
I cut my intake gaskets so I could get it around the pushrods. But then I also spray glued them to ensure that the intake gasket would not be in the airstream since I ported, polished, and gasket matched the heads and intake.
Old Jul 9, 2007 | 06:04 PM
Engine: 3.1
I followed the Haynes manual guide. Just hope I did it right.
Old Jul 9, 2007 | 06:14 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Hopefully that way works for you. I did it that way and it didn't really work.
Old Jul 9, 2007 | 06:36 PM
Engine: 3.1
When I first fire it up, what would be signs of them being mal-adjusted?
Old Jul 9, 2007 | 06:41 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I don't really know. With me it was missing, you may also hear some sort of knocking from the motor. I'm not really an expert on the subject. You might want to do a search with google or view the thread about my car that I posted a few posts ealier.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
