Took the V6 to the strip
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Well I havent found any threads with timeslips of the V6 guys but on 8-12-07 I went to island dragway in great meadows, NJ. They were having the F-body nats and was part of a meet for NJFBOA.org. This was my first time ever drag racing. Ran 2 passes. First pass I babyed it off the line and second pass I got a 16.90 @ 79.4 mph. Track air temperature was 84. Post up any of your times and what mods have been done to the car.
Far lane is me
Far lane is me
Re: Took the V6 to the strip
I posted many moons ago. 17.1 at 74.x mph (iirc). Only mod was 1.6 rockers, and cat-back? I can't remember. Never got back to the track before I blew the motor with the turbo.
Car: 1992 Camaro RS
Engine: 3.1L
How many miles do you have on the car? I've always wondered just what ours would run (83,000 miles and runs like a champ) but never bothered taking it to the track.
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
i ran a 16.8@ 79 with an slp posi as my only mod
Car: '86 SC
Engine: 2.8
how much boost were you running? and what kind of bottom end and valve train did you have (just out of curosity (SP)?
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
none. I never got to go to the track after the turbo was installed (I blew the motor being dumb and hitting the rev limiter), but the car was much faster after the turbo. The only mods I had with the 17 pass was exhaust. I was actually a couple of tenths slower once I did the fuel mods in preperation for the turbo (running rich). Member
Car: '86 SC
Engine: 2.8
i was just wondering im a cheap high schooler and im gonna have to pay for my own gas so a t/tt setup would be cheaper, lighter, and get better gas milage, (than a V8) and i meant before you blew the motor
I did all the work myself and it still cost over a grand for materials etc.
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
If your just doing a turbo because thats all the money you got now i wouldnt do it just save until you can get that V8 because you spend a grand on the V6 you will be a grand farther away from getting that V8. I would think that you would get the same gas milage as a V8. an Lt1 V8 gets 16 city and 26 highway while i get 17 city with my V6 and 28 highway. so not much of a difference there. its when you have more power and you want to start laying your foot to the floor all the time. Because I know where your coming from i am in high school and I have my foot to the floor way to often.
Car: 1998 Camaro Z28
Engine: 6.0L
last time i was at the strip my best was a 15.9, but i havent been back since i put in a cam, did some head work, intake manifold porting, and WAY better tires. although, i think ive finally hit that spot where i need a tune, because the SOTP dyno isnt as impressive as it should be anymore.
I don't have an official slip but on a section of road marked to be 1/4 mile I got up to 73-74 MPH.
Completely stock except for a home-made intake.
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Car: '86 SC
Engine: 2.8
what i was thinking about doing was putting the turbos in the back and rigging it to where i could just change the pipe goning to the intake when i do put a v8 in but what you say makes since, plus how much fun could an insurance company have with a high school kid that has a turbo camaro, thanks
.If you are on a tight budget, a V8 swap may be the way to go if you can find a good deal on both the engine and tranny (V6 tranny won't bolt to a V8), but if you know a good fabricator, the turbo can be done in a weekend. I took longer than that on mine, only because I have four kids and could barley get a couple of hours here and there to work on it. If I did it againg on another car, I'm confident it could be done in a long day (10-12hrs) at my new shop.
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
Thanks for that estimate time.
I'm glad to hear my car is running at around what it should be doin. I don't know anyone else personally who owns a third gen firebird or camaro so I don't have anyone around to compare to.
Actually, I have met one person, but he was runnin' a 350...soooo there wasn't much to compare.
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
About 40K miles ago I ran a corrected 15.8, forgot what the trap speed was though. I'll see if I still have the slip somewhere around here. I now have 273,000 miles on my 2.8 and she still runs good...needs some clutch help though...something wrong with the release fork.
Car: '86 SC
Engine: 2.8
i could probbably get and engine And a tranny for about $700 bucks
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
14.05 @ 100.96 on a rough tune hitting 15.x AFR's with my heavy *** 17" rims on... Street tires..
http://media.putfile.com/140510096
13.5's or faster coming ASAP.
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Engine: 450HP 355
Transmission: TH350
Engine: 450HP 355
Transmission: TH350
Do you want to share the cam specs with these guys? I found the Ford rockers don't work on the 3500 heads (unless longer pushrods, but then LIM clearance issues), so since a custom cam is going to be needed now for me to see .5" lift, might as well go big myself. 283 might be a touch too big, but we'll see what Delta has to say. Can't wait to see what this beast is going to do, hopefully get some nice numbers like that N/A, then throw a turbo back on it
. Supreme Member
Engine: 450HP 355
Transmission: TH350
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Peg leg burnouts rock!
But only from that side.Seriously though, I wonder what we could pull off using factory parts- like what the F.A.S.T. guys do.
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
its been a while since I've been on here...my best is a 14.97 @ 89 mph on an n/a 3.1
Car: '85 maro
Most of the v6's had open diffs... guess that's what I get for ASSuming.
Car: '85 maro
A buddy of mine had a v6 'bird with a posi, but it traded hands so many times I doubt much of it was original.
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
My car is a pegleg but that time both wheels were spinning. you can get an open diff to spin both wheels. Start off the burnout in a lower rpm until both wheels catch then let her rip.
