91 3.1 FIREBIRD wont stay running
Old Aug 15, 2007 | 04:13 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Transmission: Automatic
Axle/Gears: stock(what could be better!!)
I just bought the car from a local bank, and I gots no keys(VATS)....I got the starter and the fuel pump working, i just need to get my injectors working, anyone have any ideas?
Old Aug 15, 2007 | 04:41 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 91 3.1 FIREBIRD wont stay running
You need to buy a new ignition key lock set that comes with a VATS bypass resistor installed. You can get them from any auto parts store.
I believe there are a few other postings about VATS bypass around here as well that may help if you search...
Old Aug 16, 2007 | 01:09 AM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
problem with that is that there is 15 different resistance ranges, so I might get lucky and get the right one, if not, I will have to take it to the dealer for them to reprogram my computer, to fit the new resistor in the key.....
Old Aug 16, 2007 | 03:58 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
look for a steering column with the vats keys included and the pass box. You can look in the classified section some one has one.
Old Aug 16, 2007 | 04:02 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
thanks man. I will look and maybe post a thread...if you happen to see one, let me know will ya. that'd be great!
Old Aug 16, 2007 | 04:07 PM
kurfbird's Avatar
sure will. The Vats box is located behind the heater box under the dash PITA to get to. Will havde to be from a 1990-92 firebird or camaro
Old Aug 16, 2007 | 06:40 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Or you can bypass the VATS. There are instructions if you search about taking resistance readings and then putting a resistor to the VATS module wiring so that it doesn't matter anymore...
Old Aug 16, 2007 | 11:10 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Yeah, I guess I could try the resistor thing again, do you know which one of the wires from the ignition cylinder I need to run the resistor inline with? Thats the part that got me stuck....I really wanna get the 50-60 Hz generator and replace the Vats Box....or just replace the vats box with another one and some keys to go with it....Thanks for all the help and advice guys, if you got anything else, I would be willing to try it.
apo_bailon15
Mar 28, 2016 05:20 AM
ezobens
Aug 19, 2015 10:29 PM
the_nikfive
Aug 11, 2015 02:46 AM
Sherpajames
Aug 7, 2015 06:56 PM
