quick question for electrical connection
Old Oct 7, 2007 | 12:11 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
My fan is grounded to the firewall righ now, so its always on and my car doen't like to run cooler. I need to know what kind of connection is the fan relay on the head? I know that it is like a pin or something but I can't really see it. Can someone take a pic of theirs or tell me exactly what I will need to connect it right?
Old Oct 7, 2007 | 02:38 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
Re: quick question for electrical connection
Why don't you hook up a switch so you can turn it off when the motor has cooled down. I did and it seems to work fine.
I probably won't even mess with replacing the switch until next summer.
Old Oct 7, 2007 | 02:50 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Is this something the previous owner did for you? The V6 doesn't have a fan switch on the head if it's like the 3.1 that I have. The engine coolant temp sender on the intake manifold (by the thermostat) sends engine temp to the ECM, which in turn will activate the fan relay to energize the fan. From the factory, that temp is set ridiculously high (230 degrees IIRC).
Old Oct 7, 2007 | 04:30 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I did this because I was messing around that area of the engine and the connection went bad or somehting so I just ground it to the firewall. I don't want to wire up a switch because I don't want to and I'd don't want to be watching my temp all the time. More things that I don't want to worry about while driving. The motor is a 2.8 and the fan temp sensor to kick the fan on is in the backside of the passenger head. I just need to know what kind of connection it is. None of this "why don't you wire up a switch"?
Old Oct 7, 2007 | 06:54 PM
micali's Avatar
Engine: 2.8
if your that adiment about it then why don't you put in your post so others don't make that suggestion. I was just making a suggestion that works for me.
Old Oct 7, 2007 | 07:49 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Sorry if that post was typed in a bad day. Its been a long day for me and just having to deal with some crap that is pissing me off. My car is just going to crap all of the sudden and some other stuff is just stressing me out.
Old Oct 7, 2007 | 08:47 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
the stock replacement fan switch that i bought for my car has the button style(what the parts guy called it.) kinda weird lookin. my car does not have the fan switch wiring stock so i had to buy a connector for it we could only find one connector that even fit the thing. ill see if i cant get a pic here in a bit. http://www.rodneydickman.com/n20.html this page has a pic of one. im still looking for the connector.
EDIT: hmm looks like i got the right connector after all. sweet now to just get it put in. Damn innie plug not 1/4 but not 3/8 either but somewhere in between.
http://www.rodneydickman.com/n97.html
That guys prices are insane i got both the switch and connector for less than $20.
Old Oct 7, 2007 | 09:25 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Thanks that is exactly what I was lookig for.
Old Oct 7, 2007 | 11:21 PM
xplane's Avatar
Engine: 2.8 MFI
Your welcome. happy to help.
Old Oct 7, 2007 | 11:43 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
These engines are metric.
BRoss99
Aug 10, 2025 05:08 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
