Thinking of going v8... what are my options?
Old Oct 18, 2007 | 12:54 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
ok, so I'm thinking of buying a v8 motor. Would anyone advise against this? What are my options? I'm used to my 02 vic's 270 HP and 25 mpg highway. Is there an engine that'll give me comparable efficiency? Can my transmission handle more power as-is? What will I have to buy besides an engine? I want to go with a junk yard motor that runs - drop it in and have it re-built at a later date. I never eally drive the RS - It's just a project car for me so my options are wide open. Thanks!
Old Oct 18, 2007 | 05:09 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: Thinking of going v8... what are my options?
You will have to switch the engine and tranmission. V6 are 60 Degree and V8 and different. You will also have to switch the computer and wiring. V6 springs wont handled the v8.
Engine mounts would have to be changed. Radiator probably would have to be changed also. Its just not a drop and go.
It would be better to get a donner car that runs that way you can have all the parts that you would need
Old Oct 18, 2007 | 08:01 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Look in the engine swap forum at the V6-V8 Swap sticky. It's been very well documented there.
Old Oct 18, 2007 | 11:18 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You're best off buying a 4th gen V8 car that's been wrecked for this application. The LT1 or later LS series engines get better mileage and horsepower in a reliable package. You will need the wiring, PCM and everything else so there you go.
The nice thing about wrecked cars is that they still have most of the bolts and wires in them. Once you get everything you need from the car, strip it, sell the good parts that are left on ebay with no reserve, and throw the rest away!
Guaranteed good way to get what you want done on a budget!
Old Oct 18, 2007 | 11:59 AM
Duracell Bunny's Avatar
just sell the car and buy another car. It will be far cheaper. You would have to upgrade the suspension also for the added weight. need a new cooling system foir the larger motor... it goes on. Just sell the V6 and buy a V8.
Old Oct 18, 2007 | 12:12 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Most of those parts will go from the 4th gen to the third gen. Especially if it's a rear end collision or rollover!!
I can be sentimental. Sometimes you just want YOURS to be the way you are dreaming...
Old Oct 18, 2007 | 04:55 PM
Engine: 3.1 V6 MFI
ok, wow. I honestly thought I jsut needed an engine. That is way to hard. Heck no. I'm not doing it. Thanks for the input guys. I'm just going to juice up my v6 - there is a whole thing about in the FAQ - only thing - why can't I find headers?
Old Oct 18, 2007 | 05:15 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Pacesetter are the only company who makes headers now. Look them up on their website or look on summit for alot of parts.
Old Oct 18, 2007 | 05:18 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Check the last page of this thread www.thirdgen.org/techboard/v6/386343-after-market-parts-60-a-2.html for a list of aftermarket parts. Keep in mind that you're not limited to that list, there's a huge resource of factory parts for this engine that greatly outperform the early equipment and can be had dirt cheap from junkyards. You save about 100lbs over a v8 by keeping the v6 and get better handling to boot.
Old Oct 19, 2007 | 11:46 PM
Engine: 3.1 V6 MFI
ty!
Old Oct 20, 2007 | 06:34 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
imo get an LS1 w/ a 6spd you'll get just as good mileage as your vic, and way more power. the only problem its an expensive swap 3000-8000 depending which engine you get. LS2 is an awesome choice w/ that displacement on demand.
Old Oct 21, 2007 | 12:03 AM
firstfirebird's Avatar
Build a powerful v6
Old Oct 22, 2007 | 04:44 AM
Engine: 3.1 V6 MFI
I'm definatly going the powerful v6 route - I've been looking around the forum at some turbo posts - I think it's more in my price range. The only thing not addressed? What will a turbo do to my mileage? I would assume better b/c the engine would become more efficient?
Old Oct 22, 2007 | 02:58 PM
bl85c's Avatar
Car: '85 maro
Most will tell you that it will go out the window, but it really depends on the engine package and your driving habits. You can build a turbo engine and still get decent mileage if you can keep it out of turbo's spooling point- where the engine's doing most of the sucking, but if you're always tipping the throttle fueling goes way up with boost. Engines run much richer under boost, but can be made to run leaner at low load and boost levels where detonation isn't a problem. Aluminum heads, intercooling, a slightly oversized turbo on low boost- anything that keeps heat down will enable you to run leaner with careful tuning.
customblackbird
Aug 15, 2021 10:16 PM
Infested
May 22, 2018 11:56 PM
midge54
Jan 29, 2017 07:00 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
