Need Desperate Help!!!
Old Nov 3, 2007 | 10:39 PM
Upshotunity's Avatar
Car: 1988 Camaro
Engine: 5.0L TBI
So the deal is i got a 2.8 v6 89 before I joined the military over 2.5 years ago and I started to take the motor out. I pulled of everything and was unable to finish. I am now starting to put everything on a new motor and I am stuck with a puzzle.
I really need some detailed pics of all the brackets/bolts for them so that I know what goes where and that I use the right bolts.I pretty much need alot of pics of the engine bay and all angles. PLEASE!!!!
Old Nov 3, 2007 | 10:48 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
Re: Need Desperate Help!!!
you could just do what i do. start tryin different bolts and which ever ones fit use. start with longer ones and work your way smaller. i always use high grade stuff too. takes a while but it works. also why i usually have a lot of spare fasteners sittin around. i find one that works find out how many i need and go buy. and repeat how ever many times you need
Old Nov 3, 2007 | 10:49 PM
Car: 1988 Camaro
Engine: 5.0L TBI
sounds good but i also need to know how the brackets go.
Old Nov 4, 2007 | 09:58 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Time for you to take your digital camera to Ecology/Economy or some other huge mega junkyarrd.
It costs a couple of dollars to get in and you can spend all day there. You won't be able to see everything but you will get pics of everything you need.
Old Nov 6, 2007 | 10:26 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
i'll get some pics tomarrow. i have a similar car. i try to help our armed forces, even when their off duty.
Old Nov 7, 2007 | 12:34 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I don't have a picture, but I just finished replacing the timing cover on my 3.1 (similar setup). I had to unbolt the A/C compressor and the power steering pump on the driver's side in order to remove the water pump and timing cover - the brackets for these accessories interlock with each other and fit over the water pump.
Old Nov 7, 2007 | 06:16 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Here is a shot of the front with all everything on. Ill have to dig through my pics later to find some of the brackets.
Old Nov 7, 2007 | 10:36 AM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
You're in luck!
Hope these help...
Taken a month ago...
Unfortunately, I do not have any pictures showing exactly how the brackets for the power steering pump and A/C compressor go on...but there's really only one way they do go on.
-Everything except the PS pump and A/C compressor brackets-
(had to make these links to stay within the "10 image" limit)
http://img339.imageshack.us/my.php?i...ture001rl7.jpg
http://img339.imageshack.us/my.php?i...ture002ke1.jpg
http://img339.imageshack.us/my.php?i...ture003wo6.jpg
http://img253.imageshack.us/my.php?i...ture004ak0.jpg
http://img253.imageshack.us/my.php?i...ture005sk0.jpg
http://img103.imageshack.us/my.php?i...ture006lk8.jpg
http://img253.imageshack.us/my.php?i...ture007gr4.jpg
http://img253.imageshack.us/my.php?i...ture008rq7.jpg
I have yet to take any pictures of it sitting in the bay all hooked up...all I have right now are these...
-Shows how the PS pump bracket goes on-
Hellbillydeluxe
Sep 22, 2015 09:58 PM
camarochic
Mar 12, 2002 04:13 PM
maksik7
Feb 20, 2002 10:02 PM
IROCZ28KevinZ
Jan 13, 2002 10:37 PM
ChevyLuva3
Nov 3, 2001 08:46 PM
