Random Stalling issue
Old Mar 28, 2008 | 06:40 PM
Buss54's Avatar
I've got a 91 Firebird 3.1FI. It stalls right when i try to give it some gas after i've been stopped, but its not a constant stalling issue. I've gone 2 months without it stalling then it stalls twice in a week and its confusing the hell out of me. I've replaced the distributor cap/rotor recently, and im beginning to think its either an ECM issue or fuel issue or something man. Any help?
Old Mar 28, 2008 | 10:23 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Re: Random Stalling issue
Need some more details if you don't mind, any SES Light? any codes? does it happen when u first start up at times?, or after driving for awhile?, or is it just completely random?
Old Mar 29, 2008 | 12:13 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Dirty fuel filter?
Old Mar 29, 2008 | 01:02 PM
Buss54's Avatar
My SES light comes on and off randomly ever since the rebuilt engine. I dont have a code reader so im unaware there. Its never stalled on startup, its usually after its been running for awhile and i come to a stop light then give it gas and it just dies and even then thats random. I can fire it up in 3 seconds and runs fine, thats why its confusing the hell out of me.
Old Mar 29, 2008 | 01:32 PM
Kevin84Z28's Avatar
That really sounds like a fuel problem. Did you reroute any fuel lines near the exhaust manifold?
Old Mar 29, 2008 | 02:12 PM
Buss54's Avatar
not that i know of. im probly going to replace the fuel filter next and check the fuel lines. and if its not that, then i gotta check the fuel pump =(
Old Mar 29, 2008 | 03:16 PM
TeePEye87's Avatar
Originally Posted by Kevin84Z28
Dirty fuel filter?
That's what did it on my stalling problem, would only do it when idling or just about to leave a light. Fuel Filter was a cheap and easy fix. Big difference too.
Old Mar 29, 2008 | 09:31 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
You don't need a scanner to pull the codes. Just short pins a & b on the aldl connector, turn the key to the 'on' position and write down what the ses light flashes.
Cornholio7979
Sep 20, 2018 02:31 AM
jklein337
Sep 19, 2018 06:23 PM
777Shock777
Oct 29, 2015 04:30 PM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
