ok were is daves12secV6
Old Apr 22, 2008 | 09:39 AM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
i need his help bad daves12secV6 im tring to turbo my camaro but with rear mout turbo
Old Apr 22, 2008 | 10:35 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: ok were is daves12secV6
Gone. There's several other people that can help you here. firstfirebird is the first one that comes to mind.
Old Apr 22, 2008 | 08:14 PM
firstfirebird's Avatar
Originally Posted by Cheech Martin
Dave ain't here, man
Old Apr 22, 2008 | 09:14 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Originally Posted by firstfirebird
ROFL!!!
Old Apr 22, 2008 | 09:36 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
He just kinda disappeared a while back. Many others here can help you.
Old Apr 23, 2008 | 10:20 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
ok that were did he go it looks to me hes all over the plase
Old Apr 23, 2008 | 10:38 AM
forkvoid's Avatar
Just ask your question. We've got members very knowledgeable of turboing these motors. By the time you track him down elsewhere, your question could have already been answered.
Old Apr 24, 2008 | 09:58 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
oil feed how do i git it back there
Old Apr 24, 2008 | 10:03 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
ok will i have not move to any thing what about superchargers
Old Apr 24, 2008 | 11:43 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
ok, there's a company that specializes in rear mounted turbos, might want to look up their reviews/info. s/c are custom also (waits for them "super peeps" to chime in)
Old Apr 24, 2008 | 09:20 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Dave probably nuked his engine. LOL
You can run the return line to the oil pan or if it's above the valvecovers you could route it there. Just mount it above the oil line- gravity's the only thing bringing it back to the pan.
Old Apr 26, 2008 | 08:36 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Wow, you sure change your mind pretty fast lol. Why would you even contemplate a rear mount turbo charger anyway? I've driven in a friend's STS Corvette, and despite contrary belief, they lag, but you don't notice it because of the engine's pre-existant low end torque. Don't get me wrong though, the STS kit made one heck of a difference when they did spool, lemme tell ya....
Don't know what to tell you about Dave though. I rarely even talk about the guy, it's my cousin who has it in for him. To be honest, I feel that Dave should come back onto this website. Not only for explaining his actions with some of us, but to continue inspiring the 2.8/3.1 community. I mean, FirstFirebird, Daves12secv6, a few others, as well as myself, are far from teenagers. If you ask me, it's been going on long enough now. Just let bygones be bygones, wouldn't everyone agree....?
-Rob
Old Apr 26, 2008 | 10:19 AM
project89's Avatar
hmmmmm
anyways u would run the feed the same way u would for a front mount turbo,the hard part of the rear mount is is getting the oil back u need a pump to pump the oil back up to the motor.the good thing is u can return the oil back to the motor threw the valve cover
and it is gonna lag a .63 ex housing lagged on a front mount setup so on a rear mount i wouldnt expect boost till 4,500 rpms,u could overcome this using a .48 housing but its gonna choke the motor up top
if ur dead set on doing a rear mount i would use 2.25 inch ex all the way back,and run 2 inch charge pipes from the turbo to the tb. this smaller ex pipes would keep velocity up and help spool the turbo,the smaller charge pipes will do the same.
if ur doing all the fab work why not just do an under k member style, or even ditch the ac compressor and swap/flip the ex manifolds. and do a fm setup.the hard part with that is u need to tig weld the manifolds with nirod
Old Apr 26, 2008 | 11:47 AM
^ LMAO, why the new UserID......?
Old Apr 26, 2008 | 11:49 AM
project89's Avatar
havent been able to log into it and i dont have my old email ne more to rest the password
Old Apr 26, 2008 | 05:04 PM
Originally Posted by project89
hmmmmm
Can't flip the manifolds, the pass side manifold will hit the k-memeber/motor mount when used on the driver's side.
Easiest is to modify the y-pipe and go under the k like Dave and I did - many people have had good success with under-k's - in 4th gen fbods as well.
Old Apr 26, 2008 | 05:23 PM
project89's Avatar
its been spo long since i tried it i thought it was the driver side manifold being used on the passenger side that gave the trouble.if i remeber right it ran into the back of the alt. and the pass side fliped onto the driver side almost ran into the ac compressor.
then again if u got some cash prolyl around 200$'s u can build urself a set of headers out of steel weld els.i did mine in stainless theres about 600 just in materials on mine if not more
driverside
and passenger side
Old Apr 26, 2008 | 05:26 PM
Can't flip them over, only move them from one side to the other. Tried it
Old Apr 26, 2008 | 05:29 PM
Easiest is to modify the y-pipe and go under the k like Dave and I did....
John, umm, do you know who your talking to.....?
Old Apr 26, 2008 | 05:30 PM
project89's Avatar
though beware if u make something liek the above u will have to ditch the smog pump. im not to sure on the ac compressor mine got ditched just for the sake of losing wieght but it looks like it will fit back in
he did after that post and a pm
Old Apr 28, 2008 | 10:09 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
ok the Street Lethal vbmenu_register("postmenu_3732660", true); dude and i agree with u and im only 16 teen i have all the stuff for it i am trying to git the sts oil pump and call me doctor 6 i have a 92 camaro 3.4 v6 and a 84 supra 2.8 inline 6 80 dodge aspen 3.7 slant 6 ok lol im only 16 i love 6s
Old Apr 28, 2008 | 05:40 PM
Umm, errr, <cough>, Oooooo.... k?
Old Apr 29, 2008 | 10:02 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
ok sorry for the litte cod thing my computer dose that some times will any way have any way i have the camaro on a lift should i weld it or use coplinks
Picolini
Jun 2, 2008 11:40 PM
hachiroku_rs
Nov 17, 2007 12:06 AM
firstfirebird
Aug 20, 2007 07:05 PM
ttypecamaro
43
Jan 24, 2007 12:07 AM
koen92firebird
Nov 24, 2006 07:39 AM
