its still dead
Old May 11, 2008 | 12:48 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
its still dead
so in the last 2 weeks iv changed the battery, plugs, wires, cap, rotor ,and fuel filter and it will crank and almost start but when u let the key go it dies any help would be appreciated
Old May 11, 2008 | 12:50 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
Re: its still dead
VATS maybe? Since your car has it might be it.
Old May 11, 2008 | 12:57 PM
SageMoonblade's Avatar
Re: its still dead
Check your fuel, if it has sat for a long time it could be bad enough that it wont run. Also if you have a pin hole leak (could even be inside the fuel tank in the pick up line) that could bleed off just enough pressure to prevent the injector from firing correctly. The injectors themselves could be bad and casing the problems, check both the injectors and the wiring to them. You may also want to look over your wires to your coil. There is a chance that it is ECM related as well.
Old May 11, 2008 | 01:12 PM
fictmich's Avatar
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
Re: its still dead
It sounds like the gas is probably bad (does it still smell like gas?), your timing could be retarded too far too, that'd cause it. It won't be the VATS if your key is turning and the engine is cranking. When was the last time it ran?
Old May 11, 2008 | 01:15 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
Re: its still dead
i dont think its my gas cause right before it broke down i filled it up go figure but i was jus talking to a friend of mine and they said check the idle air control do u think that could be the problem
Old May 11, 2008 | 01:25 PM
Re: its still dead
Could be the IAC.
Old May 11, 2008 | 01:32 PM
fictmich's Avatar
Engine: 3.1
Axle/Gears: 3.23:1
Re: its still dead
So how old is the fuel then? Does the car actually start and then just die right away? If that's the case and you can keep it going by giving it gas then yes it could be the idle air control. If it doesn't start in the first place thats not the problem.
Old May 11, 2008 | 03:48 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
Re: its still dead
its about 2 or 3 weeks old now but i jus changed the fuel filter today and the fuel is good but when i crank it it sounds like it wants to start but after letting go of the key it shuts down
Old May 11, 2008 | 03:50 PM
Re: its still dead
Does it sound like its cranking at the normal speed or is it sluggish?
Old May 11, 2008 | 04:01 PM
fictmich's Avatar
Engine: 3.1
Axle/Gears: 3.23:1
Re: its still dead
Well then it's definitely not the gas. It was running 3 weeks ago right? What happened between when it was running and when the problem first occurred? Were you working on anything?
Old May 11, 2008 | 05:30 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
Re: its still dead
ya and i wasnt working on it but at first it was starting fine but when u put it in drive to go u would give it gas and it would get to about 2000 rpm or 20 mph and would die but about a week after that happened it wouldnt even do that it would jus crank
Old May 11, 2008 | 06:48 PM
threepointone's Avatar
Car: 1991 Camaro
Engine: LH0 3.1L V6
Transmission: uhh... an automatic one.
Axle/Gears: um... these ones... *points*
Re: its still dead
Mine gave me a similar response when my distributor turned and the timing went off.
Old May 11, 2008 | 09:20 PM
fictmich's Avatar
Engine: 3.1
Axle/Gears: 3.23:1
Re: its still dead
Yes, check your timing.
Old May 12, 2008 | 02:37 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
Re: its still dead
iight ill check that but what should the timing be and how can i change it
Old May 12, 2008 | 04:51 PM
fictmich's Avatar
Engine: 3.1
Axle/Gears: 3.23:1
Re: its still dead
10° and you will need a distributor wrench (15mm if I'm remembering correctly) and just barely loosen the bolt on the distributor clamp and turn the top of the distributor either clockwise or counter clockwise until you get there and tighten it down again. Oh and make sure you disconnect the tan wire with black stripe first, it breaks out of the main harness with a connector back between the strut tower and the fan in the back of the engine bay.
Old May 14, 2008 | 03:21 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
Re: its still dead
thanks im jus gonna take it to a shop get it fixed and sell it
skinny z
Carburetors
Sep 29, 2015 11:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
Jonas Earl
Sep 27, 2015 07:39 AM
Johnoooooo
Sep 22, 2015 08:55 AM
