max over bore on aluminum block?
Old May 28, 2008 | 03:17 PM
project89's Avatar
one of my uncles buddies has some old 60* stuff that im going to go take a look at he was gonna use it for a street rod project but isnt anymore.hes got an aluminum block thats already been bored and used,and some old mechanical injection stuff to go with it.i want to check the bore size on the block to make sure its still useable he thinks it was bored 30 over but isnt sure
Old May 28, 2008 | 03:24 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: max over bore on aluminum block?
Without knowing what the sleeves were designed for, you wont know how far it can be bored, dont know if you'll have a lot of trouble finding sleeves for it, but if you can then there is of course the option of having it re-sleeved.
Without knowing what the sleeves were designed for, about all you can do is take it to be sonic checked at a machine shop, they'll tell you how far you can safely go with it.
Old May 28, 2008 | 03:38 PM
project89's Avatar
i doubt the block was ever resleved form the factory but u never know the guy bought the stuff years ago and never did anything with it he also does not know the history on the stuff.ill prolly take the block anyways **** for the price i can get it for even if it needs 6 new sleves im still getiing 2.5 deals on the dam thing.but if i can id liek to rebore it and use it without having to spend more money on it, the mechanical injection im just gonna throw on a shelf and let it sit,though if i ever go ahead with my alky plans it will be much easier to setup then with fi
Old May 28, 2008 | 05:16 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
If its an aluminum block, it was sleeved, kinda cant just run aluminum bores....
Old May 28, 2008 | 06:42 PM
project89's Avatar
its a gmpp part there was a limit on bore size i just cant recall it,for some odd reason im thinking 30 over was the limit
Old May 28, 2008 | 08:52 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Technical Notes: Aluminum Bow Tie V6/60° engine blocks have rough-bored 89mm (3.504”) cylinders which can be safely over bored to 91mm (3.582”).
.078 it seems to be, so get out your instruments to find out what the bore is at now.
Old May 28, 2008 | 09:05 PM
project89's Avatar
thnx thats what i was looking for yeah i planed on measuring the bores,if its already 30 over maybe ill get lucky and can hone it if not hopefully it can be bored under 60 over,i hate to run it right at the limit
Old May 29, 2008 | 12:39 PM
firstfirebird's Avatar
Safely bored to almost .080" over! Nice. I looked at the AL blocks at one point, but the cost wasn't worth it to me since a Gen3 will be going in the car eventually anyways.
Nice to see someone finally get a hold of one and do something with it, got any pics?
Old May 29, 2008 | 02:07 PM
923.4v6's Avatar
Car: 92 Camaro RS
Engine: 3.4/3500 hybrid
Transmission: 5-speed
Do you know what manual flywheel to use with the gen3 engines in the 3 gen f-bodys?
I would like to use my 3500 bottom end and put sbc 6'' rods in it (mill .100 off the top of the pistons of course) to raise the compression. a fall project though.
Old May 29, 2008 | 02:13 PM
923.4v6's Avatar
Car: 92 Camaro RS
I also thought about boring the 3.4 block for the 3500 pistons and filling the water jackets half full of hard block for strength
Old May 29, 2008 | 02:55 PM
project89's Avatar
not yet im going to look at the block this weekend if i take it ill deff post up some pics,im pretty sure im gonan take it even if it has to be resleved it will be worth it to sit until i can afford to get 6 new sleves put it in,the mechanical injection i may keep or ebay it
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Jorlain
Oct 8, 2015 01:57 AM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
