UIM porting ideas - sandblast ?
Old Jul 11, 2008 | 09:05 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
just a thought as you cant reach deep into the plenum, could you sandblast it from the throttle body mount. surley it will then get fired through the plenum the same way as intake air and whittle away and open it up alittle inside ? i dunno just popped into my head ?
Old Jul 11, 2008 | 09:13 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: UIM porting ideas - sandblast ?
I dont think that it will stay even enough to do any good. If it does remove any metal I would think that the rear most runners(5 and 6) will have the most removed.
The inside isnt the biggest problem...the worst part of the intake is the bend from the UIM to the MIM.
Old Jul 11, 2008 | 09:29 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
cool, just an idea. stem'd really from looking at west coast fiero's rip off intake which has the noticable tube down the middle, then i just got thinking.
Old Jul 11, 2008 | 10:12 AM
project89's Avatar
the bend hurts it pretty bad,but its also the fact that the plenum volume is also very small.but u cant do anything about that short of building a new upper
Old Jul 11, 2008 | 11:09 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I have a post from a while back regarding some porting i did in that big bend between the UIM and MIM. Do a search under my name and "porting" and youll see the flow bench numbers that i gained from porting that bend. It wasnt anything amazing, but it did help.
https://www.thirdgen.org/forums/v6/3...hlight=porting
there ya go
Old Jul 11, 2008 | 01:12 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
there ya go
hi, interesting, though you never gave a final verdict on how it drives. are you up and running ok now ? and whats the verdict ?
Old Jul 12, 2008 | 07:17 AM
drdave88's Avatar
Engine: 6.0L
i did notice it helped push it a couple hundred RPM further before it falls on its face, lol. honestly, since it was free, it was worth it. if i had more time to work on it, i could have gotten more out of it, but i was in class, so i had to have it done by the end of the semester, so.... yes, if you can do it yourself, its worth it
Old Jul 12, 2008 | 11:11 AM
firstfirebird's Avatar
What you are referring to is called "extrude honing". A regular sandblaster doesn't have enough pressure or volume to remove enough material to make a difference. It actually takes a special machine for the process.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
