Trueleo intake & throttle body questions
Old Sep 1, 2008 | 09:41 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
As far as I know, only one person is running a Trueleo intake here(redraif). Anyone else?
I've got mine sitting here and I'm already at my first hurdle: the throttle body. The one I got with it is a Professional Products 'Power Throttle Body'(runs $100+ online, from what I can tell). The throttle lever is pretty much backwards from the stock one. The TPS that's on it basically is just leads. Am I required to use my original TPS, or will this one work by tying it into my wiring harness? On the bright side, it looks to be the same IAC(80406 xxxxx).
This TB seems to be alright, just gotta get through these first, unless someone has a better recommendation for a different TB?
And now for some pics...
Attached Thumbnails Trueleo intake & throttle body questions-img_1854.jpg   Trueleo intake & throttle body questions-img_1857.jpg   Trueleo intake & throttle body questions-img_1858.jpg
Old Sep 1, 2008 | 09:42 PM
forkvoid's Avatar
Re: Trueleo intake & throttle body questions
Second set of pictures....
Old Sep 2, 2008 | 05:45 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The sensor, aslong as it works in the same operating range, its fine.
Old Sep 2, 2008 | 08:07 AM
forkvoid's Avatar
And that's what I don't know about. There's no identifying markings on it that I saw, and it's a totally different design from stock.
Old Sep 2, 2008 | 09:50 AM
Dale's Avatar
Engine: 350 S-TPI
design doesnt matter. Aslong as its .50-.55volts at close/idle. And goes to 5.0volts at WOT. Its good to rock.
Old Sep 2, 2008 | 09:57 AM
forkvoid's Avatar
Excellent. I'll have to test that once I figure out the linkage issues.
Old Apr 24, 2013 | 11:19 PM
hotrodhonda02's Avatar
I am curious, did you ever get the tps wiring figured out? I can tell you this.... one is a signal, one is a positive and one is a ground..... how do I know..... let's just say I was the one who installed it and fabbed everything up.....
Old Apr 29, 2013 | 06:42 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Considering he hansn't logged in to TGO since 2010, I don't think it much matters...
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Fast355
Dec 2, 2016 06:33 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
