How to get dizzy hold down bolt on.
Old Oct 20, 2008 | 06:49 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
If I have learned anything, its easier to take apart something rather than put it back together. I got the hold down bolt off the dizzy, did what I needed to do and got the dizzy back in. BUT I CANNOT get the hold down bolt started back in the hole. I got a stupid TV cable running under the dizzy cap and its all in my way. Anything I can try or do different?
Ken
Old Oct 20, 2008 | 07:11 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: How to get dizzy hold down bolt on.
do you have an air pump? those things have a hose that will be right in your way. I attempt this car yoga position from the drivers side fender, there seems to be more room for your hand.
Old Oct 21, 2008 | 05:20 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I had the same problem with mine. I just pulled the cable out of the way long enough to get my other hand in there and start the bolt. Not sure there is a better/easier way...unless you want to unhook the TV cable.
Old Oct 21, 2008 | 07:45 AM
Stephen's Avatar
Car: 87 GTA
Do you have thhe double 90 degree tool designed for reaching that bolt? It makes all the difference in the world, reaching it.
Old Oct 21, 2008 | 09:15 AM
ken3983's Avatar
I believe the last time I did it I placed the diizy in place and positioned the clamp where it needed to be THEN place the bolt through the clamp. I don't have the 90 degree tool. The only thing I got is a Snap-0n dizzy wrench made for the task. Does'nt do me any good till I get the bolt on. LOL! I might try to nudge the TV cable outta the way first. Let ya know.
Ken
Old Oct 21, 2008 | 09:36 AM
project89's Avatar
lol that bolt is a pita do urself a favor and tie a piece of sewwing thread around it when ur trying to get it in.
ive tried getting mine in opnce and droped the dam bolt and couldnt find it cause it got stuck up on the top of the trans
easiest way u have found is to use a magnetic bolt graber and use that to lower it down into place and then use ur fingers to start the bolt so u can pull the magnet off
Old Oct 21, 2008 | 10:44 AM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
The easiest way i've found to do it is get the hold down in place first as you said Ken, look where the bolt hole is, then place the hold down there and keep it against the dist. as needed. That makes it easier to put the bolt in and not drop it.
The easiest tool i've found to use to remove and tighten it is the 15mm ratchet wrench with pivoting head. I havn't been able to find a 15mm dist. wrench, but it's deff. easier than using a swivel.
Old Oct 21, 2008 | 11:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Best is to replace the bolt with a stud & nut. Pull distributor, stuff a paper towel into hole (so no hardware ends up in the pan), install stud. Pull paper towel, put distributor back in, place clamp over stud, then washer & nut.
RBob.
Old Oct 21, 2008 | 07:16 PM
ken3983's Avatar
Well I finally got it on. I placed the clamp in position and then installed the bolt. If I EVER have to do that again, I'm going to install a threaded stud so all I have to do is place the clamp on and then a nut. Thanks for the input guys. Ditto Rbob.
Ken
evilstuie
Jan 9, 2020 08:29 PM
junkcltr
Aug 2, 2019 11:12 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
86White_T/A305
Aug 17, 2015 12:16 AM
johanlindgren
Aug 16, 2015 12:16 AM
