Cam for v6?
Old Nov 30, 2008 | 10:51 AM
Dima's Avatar
Car: 2002 Pontiac Firebird (R.I.P 1992)
Engine: 3.8L Ram Air V6 3800 Series
Transmission: 5spd
Axle/Gears: Unsure
Cam for v6?
Just needed some info on modding my 3.8 3800 series.
I want to get a couple things for it in the near future, including:
-Intake
-Headers
-Fuel Injectors
-Port Polish
-Cam
-Roller Rockers
-Valves
-Lifters
-Pistons
-UD pulley (or maybe a super/turbo charger)
-Flywheel
-NOS
-Chip
Along with a few others.
Anybody have any experience with these types of mods on the 3800? I can't seem to find any high performance parts for it on Google So if you know a website I can order them from it would be most helpful!
Also, any recommendations would be appriciated
Thanks.
Old Nov 30, 2008 | 11:49 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: Cam for v6?
is there not a 4th gen site ? 3.8's a good motor, i had it in a maro for a while, not sure about tuning but didnt pontiac have a 3.8 supercharged engine in the boneville for a bit ? thats what id look for :-)
Old Nov 30, 2008 | 11:55 AM
Dima's Avatar
Transmission: 5spd
Axle/Gears: Unsure
Re: Cam for v6?
I think there's a 5th gen site, with a 4th gen message board, but it's pretty dead. I know this is 3rd gen but I figured someone probably did a 3800 swap at some point :P
I dont really have money to get a super-charger, but do you know if the boneville one is compatable with the stock 3.8 in the 02? If so, it's pretty much a bolt on...
I checked hawks third gen too, but they don't have v6 cams. However, I did find some of the other parts I was looking into
Old Nov 30, 2008 | 12:58 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: Cam for v6?
i would have thought the blocks are the same, if you could find a scrap heap car and strip the engine youd be laughing.
http://store.summitracing.com/partde...ew=1&N=700+150+
Old Nov 30, 2008 | 02:03 PM
SageMoonblade's Avatar
Re: Cam for v6?
Hey don't be too hard on Dima. Some 89 firebirds came with a 3.8 turbo engine all be it a slightly different animal some parts do interchange engine to engine.
Old Nov 30, 2008 | 03:43 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: Cam for v6?
wasnt being hard on him ? just surprised he couldnt find any good 4th gen sites ? i didnt exactly tell him to p*&s off did i ?
good point on the TTA though, buick gn's had 3.8 turbo motors as well. it would seem you have quite a few options
as i said before i like the 3.8 motor, it will be interesting to see if you can get anywhere with it ? i wouldnt mind sticking one of them in my 3rd gen.
n/a turbo or supercharged
good luck dima, let us know
Old Nov 30, 2008 | 04:57 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Re: Cam for v6?
check out ls1tech. there are some people over there running the 3.8 also check out the GTP 3.8 supercharged engine for a (pontiac grand prix)GTP forum.
Old Nov 30, 2008 | 10:46 PM
firstfirebird's Avatar
Re: Cam for v6?
I installed an Abbott N/A cam into a 3800. Made 200whp with headers and tune.
Old Nov 30, 2008 | 10:54 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: Cam for v6?
www.camarov6.com and www.firebirdv6.com same site two diff links. im a member there i had a 98 camaro with the 3.8 they have tons of mods for them the 3.8 is a nice running motor. good luck
Old Dec 1, 2008 | 06:08 AM
Re: Cam for v6?
fullthrottlev6.com is for all v6 fbodies.
Old Dec 1, 2008 | 11:38 AM
Dima's Avatar
Transmission: 5spd
Axle/Gears: Unsure
Re: Cam for v6?
Wow I guess I have a lot of options!
I was asking if that supercharger was compatible because, as far as I understand, since you are putting more air in the engine to increase combution size, you have to change the compression ratios to compensate so you don't **** up your timing. I assumed I would have to mod the engine before bolting on the supercharger.
Oh, and also; doesn't the stock 3.8 in the 02 bird have 200HP without mods?
Thanks for the input guys, helps a lot I'll post anything I do to the car here
Old Dec 1, 2008 | 11:45 AM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
Re: Cam for v6?
200 at the fly wheel. 200 at the wheels would be more around 230HP on the engine. roughly. the supercharger from the bonnie and grand prix (and Regal and park avenue and some of those oldsmobile cars..) will not work on your car. the charger would hit the firewall and be turned the wrong way. clubgp.com is good for just general 3800 tech info, but the other listed sites will be more specific for you. I'm eventually going to try and swap a 3800 into a 3rd gen make a new age TTA (unless I can get one of those amazing 3.6L DOHC engines GM has come up with, and the 6 speed auto to go with it..)
Old Dec 1, 2008 | 12:38 PM
project89's Avatar
Re: Cam for v6?
demon i been researching the swap on the new 3.6di engines,its gonna cost more then 4k at minimum,i would look to the caddy cts 3.6 mpfi motor as it will cost alot less,though its down 35 hp from the di motor
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
