hmm
Transmission: 5-speed/T-5
Re: hmm
The small port 3100 top end is definatly a step up from the genI top end.
For free you can't complain.
Re: hmm
Free is always good
Sure 3500 is the best, but the 3500 heads don't fit the 3.1/2.8 bore anyways
Also, once you go through the top end swap, going from small to large port will be easy, so you will have room to grow.
Also, once you go through the top end swap, going from small to large port will be easy, so you will have room to grow. Thread Starter
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
Re: hmm
Hmm, I thought the 3500 fit for some reason.
Just to clarify, the large port is the 2000+ 3100 and you need to change manifolds and heads for that right?
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: hmm
Somebody forgot to nab the front engine cover...
I don't have mine either... I'm going to have to go back to that shop and say, "Hey, WTF is my timing cover? You said a month ago you were going to pull it as soon as you got a new damper puller! I paid $50 for that stuff, ALL of it!"
BTW, while I'm posting here, is the 3100 in a 98 Malibu large or small port? That's what I've got sitting in my garage right now (on a partial FWD 2.8 short block)
I don't have mine either... I'm going to have to go back to that shop and say, "Hey, WTF is my timing cover? You said a month ago you were going to pull it as soon as you got a new damper puller! I paid $50 for that stuff, ALL of it!"BTW, while I'm posting here, is the 3100 in a 98 Malibu large or small port? That's what I've got sitting in my garage right now (on a partial FWD 2.8 short block)
. Trending Topics
Re: hmm
Agreed, the FWD timing cover will be of no benefit to a RWD hybrid. The original RWD timing cover needs to be used with a slight modification of the removal of the tab that interferes with the thermostat housing.
The '98 'Bu uses a small port top end. I own one, I'm not sure if that's a good thing or not, but I own it anyway.
I also used a small port top end on my hybrid, with stamped rockers. The '98 3100 will have roller rockers.
I also used a small port top end on my hybrid, with stamped rockers. The '98 3100 will have roller rockers. Thread Starter
Engine: 3.1
Axle/Gears: 3.23:1
