NEW GUY LOL...
Old Dec 20, 2008 | 03:01 AM
beandipkilla's Avatar
Want a title? Post!
NEW GUY LOL...
Ok so here it goes i just baught a 82 camaro v6 everything is stock but has duel exhaust. has 217000 miles on but runs like a champ 4 speed. my mechanic said if it has that many miles on it 99.99% chance that engine has been rebuilt. how can i find out what kind of v6 it is. i would also like to know what i can do to make it go fasterchips,headers,intake stuff like that what should i start with..i also notice the cap and roter had 7 spark plug wires maybe i counted wrong but i am preaty sure... thanks in advance.
Old Dec 20, 2008 | 03:05 AM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
Re: NEW GUY LOL...
if its a 82 its probably the 2.8 carbed version v6. i think 1990 was when they went too the 3.1EFI unless someone did a swap wich is unlikely. if the car is clean id save up for a v8 swap its alot more bang for the buck then youll ever get pouring money into the v6 but if your intent on keeping it the only real power numbers ive seen from them are people who boost them.
your cap does have seven wires.. one runs too the coil the rest go too the plugs so your ok.
Old Dec 20, 2008 | 01:36 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: NEW GUY LOL...
if you look around you'll find a lot of stuff about intakes, although its all MPFI and not carb like you have. headers are available from pacesetter.
if you have any questions to how your engine works the best way to find out is by going to www.howstuffworks.com they have a good search engine.
Old Dec 20, 2008 | 09:56 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: NEW GUY LOL...
An *almost* worthless engine. The only reasons to build that car are to be different or sentimental value.
Take the easy road and save for a v8 car.
Old Dec 20, 2008 | 10:05 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: NEW GUY LOL...
Heh, no it's worthless. That's probably an early small main block and not worth considering putting any money into. Either get a v8 or swap in a later v6. Anything post-'85.
Old Dec 21, 2008 | 04:56 AM
MitchellDeMoor's Avatar
Car: 1991
Transmission: 700
Re: NEW GUY LOL...
Is the seventh plug wire you counted in the middle? If so that is your lead and it doesn't mean you have a seven cylinder you still have a six.
Old Dec 21, 2008 | 09:44 AM
Re: NEW GUY LOL...
wow, 217000 miles! I'd say go for the carbed V8 swap actually. it'd be easy(er) to do. just keep it going for now and start looking for a cheap 350 and a manual transmission. to see whats involved in a 350 swap go into the engine swap forum and look at the top (stickys) for the V6 to V8 thread.
Old Dec 21, 2008 | 10:35 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: NEW GUY LOL...
If you decide to stay v6, you should start with a 3.4 engine from a 4th gen. Re-use all your carb stuff to start. You just need an electric fuel pump.
Also swap to a 5 speed for better mpg and top end!
Good luck!
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
