question about the dizzy cap
Old Mar 15, 2009 | 07:15 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
one my #4 cyliner (i think its number 4 its the middle one one the drivers side) im not getting spark at all and if i move the wire to another terminal i the dizzy i get good spark. does this mean i have a bad dizzy cap? (im a little short on funding and time and i dont want to spend money on a part that wont fix my problem.)
Old Mar 15, 2009 | 07:21 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: question about the dizzy cap
pull the cap and try to clean it instead of buying one
Old Mar 15, 2009 | 08:05 PM
Car: '86 SC
Engine: 2.8
im just currious but what would/could get on it?
Old Mar 15, 2009 | 08:20 PM
Brennan's Avatar
electrical contacts usually corrode, looks like this but i doubt your dizzy would be this serious. just spray it with some contact cleaner and rub it with some sandpaper if that is your problem.
Old Mar 15, 2009 | 08:38 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
cap and rotor should cost under 20 if you end up buying one.
Old Mar 21, 2009 | 03:42 PM
Car: '86 SC
Engine: 2.8
sorry i haven't had a chance to get on for a few days i took of the cap scraped of the corrosion with screw driver put it back on and everything was fine it ran good and idled good so i guess everything ok, thanks
Old Mar 24, 2009 | 12:46 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
I know how it is with cash being short but I would recommend cap, rotor, wires and plugs. It will make a huge difference. Sometimes those caps crack and let in moisture. It seems to just find its way in there.
I learned my lesson about buying the cheap stuff too. I once but cheaper parts(even with lifetime warranty) and they didn't last that long. Yes they were warranteed but who wants to keep changing them out?
Old Mar 25, 2009 | 06:50 AM
Car: '86 SC
Engine: 2.8
ill get around to it eventually but for now its fine
junkcltr
Aug 2, 2019 11:12 PM
chazman
Aug 28, 2018 03:25 PM
GouldyGTR
Aug 21, 2015 10:43 PM
redmaroz
Aug 16, 2015 11:40 PM
92projectcamaro
Aug 6, 2015 01:20 PM
