distributer
Old Apr 26, 2009 | 12:49 PM
Dalt10's Avatar
distributer
My son and I just put in another 2.8 V6 in his Camaro. We had a rock knock so I picked up another motor. I see the distributers aren't the same as V8's as in you can only put a V8 dist in 2 ways. The right way and 180 degrees out. But on the V6 it can go in anyway you set it in there. I got the compression up on the number 1 cylinder and got the timing mark right. Started the car. I can only adjust the timing so far because the dist hits the manifold. Can I just lift the dist and move it over one or 2 notches? Or am I completely wrong with this? Car runs good but I don't have any room for timing by moving the dist. Thanks
Old Apr 26, 2009 | 01:53 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Re: distributer
I had the same problem. At TDC, the rotor should be pointed at cylinder 1. All I did was move the gear in the motor that the dist. shaft goes down into(don't remember what it was called), and moved the dist. 1 tooth over to compensate moving the gear. Was able to time my car and not worry about it hitting anything. This is a sorry explanation on what to do I know, but perhaps someone can make it a bit more clear. If not, i'm in orlando every now and then, could let you know and see if we can get it fixed.
Old Apr 26, 2009 | 02:38 PM
Dalt10's Avatar
Re: distributer
Sounds like it would work. I'll try it. Just started the car and got oil all over the driveway and couldn't figure out why. Looked and didn't have the dist tightened down and leaked all over the place. Here is the pic of the Camaro. He got it for $900 with a rod knock. Picked up a motor for $250.
Here's mine. 87 Monte Carlo SS Aero
Old Apr 26, 2009 | 02:55 PM
Car: 1991 Firebird
Engine: 3.1L V6
Re: distributer
Ha, i've done that before...luckily didn't get oil everywhere though. Nice monte. Let me know if what I suggested works for you.
Old Apr 26, 2009 | 05:42 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: distributer
killswitch engage nice.. anyway.. i need to know how to set the timing on the 2.8. its off just a little and gets worse at high rpm's
Old Apr 27, 2009 | 09:20 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: distributer
10 degrees btdc run #1 cylender up to 10 degrees. install dissy should be pointing at number 1 wire.
Old Apr 27, 2009 | 01:50 PM
AmorgetRS's Avatar
Re: distributer
Sounds like you need a new o-ring on the dizzy. They normally get really hard like plastic and no longer seal, causing oil leaks at the back of the motor. Very very very common.
Old May 3, 2009 | 09:34 PM
Dalt10's Avatar
Re: distributer
Put on new O ring today moved dist over one notch/gear and runs great and have plenty of room to get the timing set. Thanks,
Old May 4, 2009 | 09:39 PM
Car: 1991 Firebird
Engine: 3.1L V6
Re: distributer
Awesome, good to hear.
db057
Apr 28, 2019 07:45 AM
Gunner242
Dec 25, 2015 04:49 PM
drptop70ss
Oct 4, 2015 09:44 PM
dusterbd
Sep 29, 2015 08:40 AM
pimprs
Aug 24, 2015 11:20 PM
