Pacesetter Problems
Old May 28, 2009 | 07:16 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Pacesetter Problems
I've got a set of pacesetter headers on my 3.4l (same block as 2.8) and none of my alternator brackets will fit anymore (the ones that were on the manifold I mean).. Is there anything I can do? I really don't want to put the manifolds back on after all that work. Will the bracket holding the alternator and the belt tensioner hold it and not break?
Old May 28, 2009 | 09:09 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: Pacesetter Problems
pictures would be great.
Old Jun 1, 2009 | 07:40 PM
firstfirebird's Avatar
Your alternator is on the passenger side right? I don't remember there being a bracket that bolted to the exhaust manifold, and if there was, I didn't have it on mine and it worked just fine.
Old Jun 1, 2009 | 07:51 PM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Yeah on mine the alternator bracket runs to the front left top of the UIM. But I never put it back on and have not hade any problems yet.
Old Jun 1, 2009 | 10:23 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Im not really 100%...havent seen my engine stock in a while...but it looks like the bracket behind the alt hooks to the top from bolt on the passenger side manifold.
If you are really worried about it, you could just buy a threaded stud and add make it work. all you would need it a spacer in between the header flange and where the bracket is.
Old Jun 2, 2009 | 03:05 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I don't even have that bracket on my engine but someone else did the 3.4 swap, even without the bracket it seems pretty strong.
Old Jun 2, 2009 | 08:38 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
well just to be safe, I took of the headers and put the manifolds back on. My dad and I are going to make spacers for them sometime and get them to fit like the manifolds do.
Swaps done also, SO MUCH TORQUE!
Old Jun 4, 2009 | 11:13 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I left the bracket off when i put mine on back in 05, never had a problem yet. I wouldnt waste the time w/ spacers and all that, just put em on, bolt the rest of the alternator back up and forget that bracket was ever there. you wont have any problems.
Old Jun 8, 2009 | 07:07 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Left my bracket off too. No problems
pjsparts
Oct 29, 2025 06:39 PM
92projectcamaro
Jan 18, 2016 08:00 AM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
