throttle body coolant by pass
Old Jun 3, 2009 | 09:59 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
has any one done this to these cars? i bypassed mine today and it seems to be a bit peppy-er.
Old Jun 3, 2009 | 10:52 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: throttle body coolant by pass
the air don't heat up so much when entering the tb. thats about it.
Old Jun 4, 2009 | 10:52 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
http://thirdgenmods.firebirdv6.com/tbcoolant.html
It's been bone... but I find it hard to believe the gains are worth the work. How much time does air comming into your engine spend passing through the TB, like .001 seconds?
Old Jun 4, 2009 | 11:03 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Not necessarily a good idea in cold weather climates. Some people have mentioned throttle body freezing, not sure if it would happen or not though. Something to keep in mind since youre in Ohio though.
Old Jun 4, 2009 | 10:39 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
don't think it's worth your time, but you already did it so I'd leave it.
drdave-still getting your camaro out this summer?
Old Jun 4, 2009 | 11:53 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
I tried it today, just to see what it would be like. Didn't get as sluggish as fast, and after driving in 80 degree weather, I could actually touch the TB. Doesn't make it go faster or anything, I didn't notice a gain at all, just it staying cooler just a little bit longer. I might not keep it bypassed when I swap my motor.
Unless you take it to a dyno, and do a couple runs without the bypass and then a couple with the bypass. I doubt anything will improve. And if you don't drive your Camaro in the winter, then go ahead and keep it bypassed. How did you do yours? I just used one of the original hoses and bent it to fit onto the other, works fine and doesn't kink.
Old Jun 5, 2009 | 08:26 AM
drdave88's Avatar
Engine: 6.0L
chevyracingrox - its been out for about a month now on the road, no triips to the drag strip yet, probably wont this year either. it needs some work and im w/o a garage to work on it.
Old Aug 5, 2009 | 01:22 AM
irocman79's Avatar
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
what did you cover the coolant ports on the throttle body with
Old Aug 5, 2009 | 01:29 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
It did a whole lotta nothing for me.
Old Aug 5, 2009 | 06:29 AM
drdave88's Avatar
Engine: 6.0L
Dont need to cover the ports on the TB w/ anything, no reason to really.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
