Stallin issue.
Old Jun 20, 2009 | 02:39 PM
92slomarro's Avatar
Stallin issue.
Ok here is my problem. I can start my car up it will idle fine right around 800 rpm. I can drive normally after start up but once the car hit normal operating temp i start having problems. The car will drive normally until I start to stop for a light or make a turn the car will drop rpms while down shifting to around 200 rpm an lower until the car is stopped completely. sometimes the car will stall while going through this and the issue happens even if im not using the brakes. I have recently replaced pretty much the whole eletrical system due to another issue I had earlier. any ideas?
Old Jun 25, 2009 | 08:26 AM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
Re: Stallin issue.
try raising the idle
Old Jun 28, 2009 | 07:44 PM
Jake08's Avatar
Re: Stallin issue.
Bump. Having the same issue.
How does one go about raising the idle on a MPFI 3.1L?
Old Jun 28, 2009 | 09:41 PM
92Birdofprey's Avatar
Car: 92 Firebird
Engine: 3.1
Axle/Gears: stock, dynomax turbo exhaust
Re: Stallin issue.
I'm having the exact same issue, and I am also wondering how i would raise the idle, I thought that its recommended not to touch the idle. If its possible, how can we do this?
Old Jun 29, 2009 | 09:50 AM
entrig00's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: t-5
Re: Stallin issue.
for the 3.1 the idle is set where it should be. I'm going through the same problem and its ticking me off. I tried changing the fuel filter ....not that, changed out the fuel regulator....not that, I dont know how to check the fuel pressure so I'm out of luck on that.
Are you guys getting error codes? How do you check that on your own. I know the newer cars you can take it to autozone and they can do a check for free....
Thanks.....
Old Jul 5, 2009 | 08:46 AM
aza454's Avatar
Car: 1987 Chevrolet Camaro RS
Engine: 2.8L MFI V6
Transmission: Auto w/Manual OD
Re: Stallin issue.
hey guys dunno if this will help or not, but my car was doing the same sort of thing, turns out there was a pipe that wasn't fitted really good going to the brake booster and so = vacuum leak = stall (i think) anyway I cut a new pipe and it goes fine now...
Old Jul 10, 2009 | 04:17 AM
92slomarro's Avatar
Re: Stallin issue.
Im not sure... Im at a loss on this one its an on and off thing with my car. I think its getting about time to buy the 2010 ss and rebuild this mess I have now...
Old Jul 12, 2009 | 01:43 AM
aza454's Avatar
Engine: 2.8L MFI V6
Re: Stallin issue.
They're bloody picky things. My car stalls now for some reason, but only once you try starting it again after a short drive...very confusing. Any help anyone?
Old Jul 18, 2009 | 02:57 PM
Poptart's Avatar
Car: '91 Firebird
Engine: V6
Re: Stallin issue.
My bird had the same problem when i picked it up back in january.
I still have yet to completely fix the stall problem but I have narrowed it down to only stalling when I have low fuel.
Ive replaced the FPR diaphragm, fuel filter, vacuum lines and a few other things but those three were the only ones related to the fuel system.
In response to the original problem what may be happening is since it runs fine at first there may be rust deposits in the gas tank or line and may clog up the line slowly as the car runs. Thats what I was told anyway, have yet to drop my gas tank and check it out. The fuel filter was full of rust though.
Giocio
Oct 1, 2015 12:20 PM
Lmancha96
Sep 25, 2015 08:11 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
