Turbo Question
Old Nov 5, 2009 | 02:27 PM
jon 89 RS's Avatar
Car: 89 camaro rs
Engine: 2.8L
Turbo Question
Alright guys i need a little help identifying which are the oil in/out and water in/out?
Attached Thumbnails Turbo Question-turbo-1.jpg   Turbo Question-turbo-2.jpg   Turbo Question-turbo-3.jpg
Old Nov 5, 2009 | 03:10 PM
project89's Avatar
Re: Turbo Question
square hole is the oil outlet, hole oposite that is the oil feed
the 2 brass fittings are water in and out, it dosent matter which on u use as in or out on those
Old Nov 5, 2009 | 11:35 PM
jon 89 RS's Avatar
Car: 89 camaro rs
Engine: 2.8L
Re: Turbo Question
sweet, thanks project 89.
Old Nov 10, 2009 | 11:56 AM
jon 89 RS's Avatar
Car: 89 camaro rs
Engine: 2.8L
Re: Turbo Question
hey project89 I have another question on the thread "How to: Installing a Turbo" I saw in a picture that you left the stock o2 sensor in place. Is that necessary? or just as long as you have the other o2 sensor that's right on the hot side tubing (close to the turbo)?
Old Nov 10, 2009 | 01:50 PM
project89's Avatar
Re: Turbo Question
dont use the stock location, put the o2 sensor on the turbo outlet, and u will also need to use a heated 02 sensor
Old Dec 1, 2009 | 01:15 PM
jon 89 RS's Avatar
Car: 89 camaro rs
Engine: 2.8L
Re: Turbo Question
I have a few more questions. Now if i'm right the IAT sensor goes between the intercooler and the throttle body. My question is, Does it matter if it is before or after the bov? My other question is instead of having to weld a bung on the oil pan for the oil drain can you use the oil dipstick tube and maybe right before it enters the pan cut it and put some type of "Y" fitting?
Old Dec 1, 2009 | 05:41 PM
project89's Avatar
Re: Turbo Question
yes u deff want the iat between in the intercooler to tb pipe, it does not matter if it is before or after the blow off valve
no u cannot use the dipstick tube, biggest reason is its not big enough and oil would back up into the turbo
Old Dec 16, 2009 | 02:24 PM
jon 89 RS's Avatar
Car: 89 camaro rs
Engine: 2.8L
Re: Turbo Question
and some more questions. I was looking around trying to see how to connect the boost controller, boost gauge and such and i found the following diagram. Was wondering if it is ok to follow this diagram?
Old Dec 23, 2009 | 10:33 AM
jon 89 RS's Avatar
Car: 89 camaro rs
Engine: 2.8L
Re: Turbo Question
anyone?
Old Dec 26, 2009 | 01:04 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: Turbo Question
the diagram looks ok. the only thing is... there are a couple ways to hook up boost controllers and wastegates, just read the directions on the one(s) you buy.
By the way, I have a y-pipe and stainless steel downpipe (with wastegate) that will mount that Chrysler turbo in your pictures I can let go cheap. it mounts in front of the motor just like the "how to..." sticky.
Old Jan 2, 2010 | 11:14 AM
jon 89 RS's Avatar
Car: 89 camaro rs
Engine: 2.8L
Re: Turbo Question
ok thanks, I also wanted to make sure if -3 an oil feed line and -10 an oil drain is fine for the turbo i have? once again thanks
Old Jan 2, 2010 | 05:03 PM
oil pan 4's Avatar
Car: 89 Firebird
Re: Turbo Question
I know what you need.
Maximum Boost by Corky Bell, its got a lot of small hows and whys for some thing like you need.
If you want even more HPbooks publishes "Turbochargers" its more indepth and covers pretty much every thing.
Old Jan 2, 2010 | 05:08 PM
Re: Turbo Question
those size hoses are ok. The cheapest internet source I've found is McMaster.com
Page 247 of the online catalog.
-4 braided hose (3/16"ID), Part number: 4468K811 (specify length)
-10 braided hose (1/2"ID), Part number: 4468K814 (specify length)
fasteddi
Sep 2, 2015 10:29 AM
lt1z350
Aug 28, 2015 05:57 AM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
