3.4 Swap
Old Mar 5, 2010 | 10:20 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
3.4 Swap
Going tomorrow to pick up a 3.4 from a 1995 Camaro has 90,000 miles on it.
Guy saids it needs headgasket. Getting alot of free stuff with it
(NO INJECTORS) DOes anyone know what other kind of cars have the 17 lb injectors.
Been reading the threads on the swaps
Its going in my 91 camaro.
Will keep you updated on the swap.
Going to replace the
Headgaskets.
Timing chain
Freeze plugs
Oil pan gasket
Water pump
Rear main seal
Old Mar 6, 2010 | 11:36 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 3.4 Swap
Do you need to replace the injectors? Are you looking for factory ones?
The fuel injectors are 18.4 lb/hr, same as the pre-00 3100s.
Old Mar 6, 2010 | 05:17 PM
kurfbird's Avatar
Re: 3.4 Swap
thanks. He did not have the injectors with the engine.
Got the complete engine with intake and everything for 50.00
Old Mar 6, 2010 | 05:39 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: 3.4 Swap
$50? Man, if I could find a 3.4 for that price, I'd carry it home on my BACK if I had to (no truck ). Well, okay, I almost had the whole 3100 I got the head parts off of for $50, but there was no way to get it home (not like the engine was going to sit in my back seat all nice, right?) You got lucky there. Just make sure it spins freely.
Old Mar 6, 2010 | 11:25 PM
kurfbird's Avatar
Re: 3.4 Swap
Turns freely checked it before I brought it. Pulled all the 3.4 stuff off of it and set it ona tire.
Old Mar 7, 2010 | 09:53 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: 3.4 Swap
Well, as long as it's out, you could go ahead and throw some 3400 heads and intake on it and call it a day. It's already set up for the DIS, so it would make things a lot easier.
:edit: Oh, and when you do the RMS, it might be a good idea to replace the seal on either the dizzy or the oil pump drive (depending on which way you go with the swap) and either RTV seal or replace the gasket on the rear cam plate as well. BTW, you can get the MEMCAL from a 93 3.4 (non-SFI, still has a MEMCAL and uses the 16149396 ECM, same as the 92-93 3400 DOHC) and run the DIS if you're up to it, so you don't have to screw with the dizzy.
Old Mar 8, 2010 | 12:45 AM
kurfbird's Avatar
Re: 3.4 Swap
Have some 3.1 heads I had redone last year. Going to use them
Order timing chain
Gaskets set timing cover / Head gasket set
Rear main seals and oil pan gasket.
OOPS forgot freeze plugs
Going to the dealer for the cam seal.
Old Mar 21, 2010 | 10:01 PM
kurfbird's Avatar
Re: 3.4 Swap
got some injectors at the yard this weekend
Old Aug 30, 2010 | 11:20 PM
kurfbird's Avatar
Re: 3.4 Swap
Everyhthing is done and the motor is installed. I am prety sure the distributor is 180 out. Cranks but wont run. Will look at it tomorrow.
Old Jan 17, 2011 | 11:48 AM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
Re: 3.4 Swap
hey i have a 1991 camaro its a 3.1 im looking to put in a 3.4 v6. you dont need to change anything?
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92projectcamaro
Aug 6, 2015 01:20 PM
