Disadvantage/Advantage to running Z28 front/rear swaybars?
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Picked up some suspension parts from a 87 Z28. Sway bar, some weird brace that goes on the frame rails i guess? and front and rear springs. Im keeping the springs incase I go the v8 route, but any advantage to running these or would they be overkill, the front bar seems pretty thick.
Car: check
Engine: check
Transmission: check
Re: Disadvantage/Advantage to running Z28 front/rear swaybars?
RBob.
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
The frame brace (wonder bar) will get in the way of your lower radiatior hose. That didnt stop me though, I just set the hose on top of the bar for now. If you figure out a better soloution LMK!
I do notice a little less roll with the bar and I imagine the difference will be huge with the wonder bar and V8 swaybars.
Ok cool, just wanted to make sure it was going to help and not hurt performance (well cornering i guess lol)
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If you cornor HARD HARD, like autocross hard, the rear will be to much. I kept pulling a tire off the ground when I had that.
Its gonna be my daily driver. Since Im lacking on power, I figure at least have fun on onramps and such.
u will love the upgrade specially the steering brace
i have a 1le set with brace on my car and its the best thing i ever did besides the turbo charger
Car: check
Engine: check
Transmission: check
RBob.
Car: check
Engine: check
Transmission: check
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
so can u all tell me whats better the sway bars of a 84 trans am or 85+ irocz camaro i think thay were both 5.0s
Car: 87 GTA
Put on the steering brace (wonder bar), the large front sway bar, but what size rear sway bar does your car have now?
The large rear bar held the axle too much & reduced weight transfer.
Going to a smaller than the stock IROC/WS6 rear bar (24mm, IIRC) will make it better. If you have a 17mm or 19mm, that is pretty much what you want for the rear.
Thanks Stephen, Ill measure them tomorrow with my trusty sway bar measuring tool and go from there.
Engine: 350 S-TPI
V8 with LSD, I could tell the left was as well, but not as much as the right.
I'm running 36/19. I may bump back up to 21 or so just to get poly mount bushings.
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I have 36mm hollow front & spohn chromoly 25mm rear and it would certainly lift the rear. You can still use a larger rear bar and move the axle mounts in a bit to reduce ridgitity. I moved mine in 1/2" and the rear stays planted now.
1992rs/ss
16
Jan 28, 2016 09:58 PM
GVMV
Aug 16, 2015 08:01 PM
