wonderbar and lower radiator hose?
Old May 2, 2010 | 07:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i put a wonder bar on my 92 tonight along with my new crosslaces, and the lower radiator hose and support bracket were really in the way, had to remove, re bend and reinstall the support brace. The brace is sitting right on the wonderbar, so nothing rubs the hose, but its still right there.
Haven't ever heard of this before? anybody else have this issue? is there a different lower hose i can use thats routed differently? maybe from an earlier car?
Old May 2, 2010 | 08:40 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: wonderbar and lower radiator hose?
I had the same issue with a global west bar. I just smashed the hose up a bit and put on the wonderbar. Definitely in contact, but no issues so far.
Old May 2, 2010 | 09:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No problem here with the Global West bar.
JamesC
Old May 2, 2010 | 10:22 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Put the wonderbar on this spring, had the same issue, just let the hose set on top of the bar.
Thinking about getting some big zip ties to make sure the hose doesn't move or rub too much.
Old May 3, 2010 | 03:38 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Mine does the same- no issues though. It shouldn't matter that is just sits on top- it is just effectively resting on a frame member.
I did have an issue with my wire harness when I went to put the wonder bar in. Someone had zip tied the harness to the center link, so every time I turned the wheel, the harness was yanked back and forth!!
Amazing what passes for 'maintenance' with some people...
Old May 3, 2010 | 07:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
ok then, its not just me. thats good.
Im leaving it as it is, i still have the sheetmetal lower support for the hose installed and thats keeping the hose off the bar, hopefully it doesnt vibrate and rub off all the nice powdercoating
Old May 3, 2010 | 07:47 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I'm using the wonder bar from TDS and I do not have that problem. The hose is close, but there is no contact.
Old May 3, 2010 | 08:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
this is a v6 car, the routing is different, and pretty stupid IMO.
Old May 3, 2010 | 08:51 PM
87WS6's Avatar
True. I've never done the installation on a V6 car.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
snakeshooter
Sep 10, 2015 07:46 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
