Pass side coolant leak...
Old May 4, 2010 | 06:03 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I'm sure its something missing, just not sure what and or where it goes, basically somewhere on my pass side of engine when i put new coolant in it drained right out, somewhere above starter and below cyl head. Pictures would help greatly, I need to know where it is, and what I need to get to plug it....
Old May 4, 2010 | 06:07 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
Re: Pass side coolant leak...
Maybe a freeze plug.
Old May 4, 2010 | 06:42 PM
Engine: 3.8, 3.4
Disregard post, mother****ing godamned block is ****ing cracked.
Old May 4, 2010 | 06:58 PM
Car: 92 camaro B4C
Transmission: t5
That's the sh**s time for a v8 ?.
Old May 4, 2010 | 07:02 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Old May 4, 2010 | 07:09 PM
Engine: 3.8, 3.4
If I didn't have close to a grand in my 6 and wanted an 8, then yeah it might be, but that's not the case, I'm either going to try having it welded or get a 3.4 shortblock......unfortunately this means more time, money and patience, all of which are in short supply of late.
Attached Thumbnails Pass side coolant leak...-100_0437.jpg   Pass side coolant leak...-100_0438.jpg   Pass side coolant leak...-100_0441.jpg
Old May 4, 2010 | 07:16 PM
project89's Avatar
thats the exact spot my block cracked but mine was only an inch long max i can weld that but i wouldnt trust it the crack is just way to big, its deff time to search for a 3.4 shortblock or a 3.1 if u cant find one
Old May 6, 2010 | 12:14 AM
cj92firebird's Avatar
Car: 92 Pontiac Firebird
Engine: 3.1L FI
Transmission: Borg Warner T5
Axle/Gears: Stock 3.42
I have a 3.1 L block that I just took outta my car because it needs freeze plugs. The block isn't cracked or anything, it needs a freeze plug behind the flywheel, and a crank kit, cause it is seized up.
LittleFranks
Sep 17, 2015 12:22 PM
Bstrang6
Sep 8, 2015 04:29 PM
downsouthboy
Aug 29, 2015 11:29 AM
wruiz
Aug 11, 2015 02:59 PM
3rdgenparts
Aug 5, 2015 11:57 PM
