Anyone on here running 4th gen headers?
Old Jun 28, 2010 | 09:19 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
A couple of guys and I are looking for some info on headers, specifically the older PaceSetters that were made exclusively for the 3.4 in the 4th gen as they are used in the 3rd gen. Anyone on here have a set that can tell us how they were modified to work in our cars? I'm looking for info on a similar set of headers, but not too many people have heard of them. Since the PaceSetters were used first before PFE came out with the 2.8/3.1 versions, I was thinking that someone on here would know how to modify the 4th gen headers to work in our cars.
Old Jun 29, 2010 | 12:06 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: Anyone on here running 4th gen headers?
What would need to be modified? my 2.8 and my 3.4 manifolds are basically the same. Or are you refering to the longtubes?
Old Jun 29, 2010 | 06:54 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I wanna say it was KED85 that had a whole thread on his car being used as the test car for fabbing up headers for our cars a while back. there were pics of the fabbed headers used, it showed some pics of different pieces that were welded in to make the 4th gens fit into our cars. not sure if that helps you at all, but i do remember a thread on it and seeing pics
Old Jun 29, 2010 | 01:50 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Search my old threads that I started, I'm one of very few that bought those headers and prob the only with stainless. They made them before pacesetter produced them for third gens
Old Jun 29, 2010 | 06:17 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Aw... I was hoping I wouldn't have to use the search system as it really stinks... I'll see what I can find if anything, I suppose.
:edit: Searched... Went through every one of KED85's posts I could find and found no pics. Several threads had links to sites that don't exist anymore. I was hoping for pics of how those who have the 4th gen headers on the 3rd gen engine have them altered. Also found a thread referring to S10 headers and their use, but no info more than that. There was a couple threads referring to an older thread that is no longer in the system as well.
Old Jun 29, 2010 | 10:32 PM
Pillsbry10's Avatar
its a short list in my threads started and its titled pf&e...bout the only one that has any info on them and some people that have them
Old Jun 30, 2010 | 04:12 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Searched your topics and found a dead link (where the pics apparently are, deadbird.org or something) and a set of FWD headers.
Old Jun 30, 2010 | 07:45 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
I seem to have tracked down a number to a Performance Fabrication & Engineering (PF&E): 586-949-3400
I think Pillsbry10 has had dealings with them. They may have what we're looking for. I think there have been some problems with these guys, though.
Also, I'm not sure if they've every done a set of 3.4/3x00 hybrid motor headers. Since they are in Michigan, I may allow my car to be a test-subject...
Old Jun 30, 2010 | 09:06 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Pillsbry, what is the size of the primaries on those headers? We're looking for around 1 3/4".
I saw another TGO member's CarDomain page and she has/had the PF&E headers. Space is tight, and the y-pipe is quite odd, to say the least. Although I'm not interested in a y-pipe... I've had way too much difficulty over time with the thing. I have something cooking in my head that could be interesting. I'll have to see if I can find a different set of headers, say, from an S10 (read in another thread last night that those may fit except for the fact I have a T5), which would be right along the lines of what I'm looking for, provided I can find the right primaries.
Old Jun 30, 2010 | 10:41 PM
Pillsbry10's Avatar
yeah i bought mine back in like 2003ish so they may not be in business or even making things anymore
the primaries on mine are 1.50 i belive
Old Jul 1, 2010 | 09:25 AM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
That number is OLD, and I doubt it still works. I did find another number for them, but I lost the link and still can't find it again. I hope to track it down...sometime. Anyways, I'd be happy with 1-5/8" primaries for some better velocity to my remote-mount turbo, but I can't do 1-1/2" with those exhaust ports on the 3x00 heads. The search continues...
Old Jul 1, 2010 | 09:28 AM
Engine: 2.7L V6
Axle/Gears: 4.41
1 5/8" at the bare minimum, not counting porting the heads... Which is why we're looking for pics of anyone having modified the 3.4 PaceSetter 4th gen headers to see what might have to be done with a set of the RKSport headers that have the 1 3/4" primaries.
Old Jul 1, 2010 | 06:42 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Yeah, I'd love to find out what has to be done to those RKSport headers to make them work on 3x00 cylinder heads. Hopefully, not much...
Old Jul 1, 2010 | 07:11 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
From what I have read, one side works without modding- the other side, you have to put in a vise, heat it up and bend it to clear the firewall I think. Then have a new Y pipe fabbed. But they do bolt up to the heads OK, since the 2.8/3.1/3.4 heads are all the same. I am just going to go with some 2.8 pacesetters on my 3.1 and have the smog crap fabbed up to fit. Stupid Kulifornia!!
Old Jul 1, 2010 | 07:22 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
POSSIBILITY: Does anyone have a set of 3.4L V6 (NOT 3400 V6) cylinder heads sitting around? If someone does, and doesn't mind spending $20 bucks, go to Auto Zone and buy a set of 3400 V6 (NOT 3.4L V6) exhaust manifold gaskets, PN MS95586. Then, whomever can just place them on the cylinder head and check clearances. Just a thought...
Old Jul 1, 2010 | 07:33 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The bolts don't line up... I already knew that as the gen II heads are different from the gen 1 and the guy who replaced my 2.8 tried to use an FWD engine... The holes have to be enlarged in the headers to accept the 3x00 bolt pattern. I have the gaskets AND the 3x00 manifolds sitting in my garage (because I can't get the EGR transfer tube out of the rear manifold which is broken in half).
Guess one of us is going to have to get a set and find out which one needs to be squished. The y-pipe is a non-issue for me at this point. However, getting my quarter panel replaced IS...
Old Jul 2, 2010 | 09:48 AM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
We already knew that the bolts on the 3x00 heads and the bolt-holes on the RKSport 3.4L headers wouldn't line up, right? The main question is whether or not the primaries of the RKSport headers will line up with a set of 3x00 heads, isn't it? Bending and re-aligning the pipe AFTER the collector doesn't bother me one bit. Neither does slotting bolt-holes on the header flange bother me. Trying to see if these headers will fit on the 3x00 heads without modifying the primaries and flange is my question.
Old Jul 2, 2010 | 02:19 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The pipes have to be bent BEFORE the collector to get the header on one side to clear the frame rail and other parts. I'm trying to figure out which side. Other than that, I haven't heard of any further modification necessary. I'm surprised there isn't more response to this. I guess everyone DID leave the site.
Old Jul 2, 2010 | 03:06 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Oh, okay, my bad. I didn't have all of the facts before I opened my mouth...it happens...ONCE IN A WHILE.
I was hoping for some more input and info on this as well...
Old Jul 2, 2010 | 03:10 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Yep... Modernizing something that's 23+ years old is a pain and not easy. Looks like I might have to find a welder... As if the torch wasn't going to be bad enough.
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
Elliswon
Aug 10, 2015 12:33 PM
