2.8 liter to 3.1 liter
Old Aug 15, 2010 | 01:06 PM
Delner's Avatar
Car: 87, 88 Firebird 84, 00 Camaro
Hey Guys,
i have a question, can i drill up a 2.8 Liter Motor to 3.1 Liter?
Thanks for answere
Old Aug 15, 2010 | 01:54 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: 2.8 liter to 3.1 liter
the 2.8 and 3.1 share the same block, the difference is the stroke of the crank. 2.99" VS 3.31"
To make it a 3.1 you'll need the 3.1 crank and the 3.1 pistons, the rods are the same and so is everything else.
Old Aug 15, 2010 | 03:25 PM
Delner's Avatar
are the comp´s of the cranks are the same? ore have they bigger to?
its because in germany its very expensive bigger motor´s
thus in the paper stay 2800 and i know its 3100
Thus i have to change Crank and Pistons?
all other thinks are the same right?
thus i like to get more Power from this Motor,
i found Ceramic Headers - Ultra Flow Kat
what can i do more? a sharp camshaft?
gives there better heads?
i like to get arround 200 HP from the Motor ore more
Old Aug 15, 2010 | 04:15 PM
Engine: 450HP 355
Transmission: TH350
Originally Posted by badass_camaro
Jesus christ what the hell is wrong with some of you. Why on earth would you waste time or money doing that? A 3.1....really? You might as well just throw a briggs and stratton in there.
Dude, seriously.. GTFO.
Old Aug 15, 2010 | 04:20 PM
Engine: 450HP 355
Transmission: TH350
200 won't happen on the iron heads, they don't flow enough.
If the 2.8 is running fine then i'd suggest a nitrous kit or a turbo. going to a 3.1 only gains a little torque and about 10 HP.
Old Aug 15, 2010 | 05:01 PM
Delner's Avatar
I have enough Time and enough Money for doing that.
Have 2 Firebird´s and 1 Camaro third gen 1 Camaro 4th gen
at the moment i like to push up the 2.8l a bit for my son.
Old Aug 15, 2010 | 05:30 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
If you're going to do all of that, save yourself the time and effort of getting into the block.
Pull the motor, and install a bigger V6 block from a later car (I can't remember if it's 3.4 or 3.8, or maybe both, read around in here) to get the extra power. If you still want more pull, put a 3.73 rear end in it. That is the best option IMO.
My stock 3.1 with a manual transmission pulls itself around great. Ditch the automatic if it has one, they rob you of 10% or so of what little power you have to begin with
Old Aug 15, 2010 | 06:35 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Everything depends on the availability of the parts, being overseas and all. You could, if you could get your hands on tuning equipment, swap the crank, keeping the 2.8 pistons, and have a bit more power over the 3.1 pistons and crank alone due to higher compression, but you're better off starting with a 3.1 shortblock and swapping everything over from the 2.8. And then, of course, get a bigger cam, 1.6:1 ratio roller rockers, headers, and port/polish the intake and heads.
Old Aug 16, 2010 | 06:33 AM
Delner's Avatar
Thus i have to get a 3.1 litre block
aluminum heads are ok and better than iron heads right?
roller rockers
how u mean with get a bigger Cam? do u know a website where i can find good parts for the 2.8 ore 3.1 liter engine?
i found many on Summitracing but i think there gives more good thinks.
i think better fuel injectors with 21 lbs? the original have 15 lbs?
what parts are interesting to?
i think over a turbocharging.....
Old Aug 16, 2010 | 09:21 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
If you're going to go to the trouble of swapping in a different shortblock, then try to get a 3.4l v6 out of a 93-95 F-body, put in a bigger cam, not sure what you mean about summit, but they have some good cam choices, just buy it for the 2.8 if you get the 3.4 because the 3.4 selection is alot less due to it being slightly different because it has a timing mark on it for sequential fuel injection, other parts I suggest would be headers and a catback exhaust and a bit of head/intake porting, bigger injectors won't hurt either, this stuff on a 3.4 should make 200 hp relatively easy.
Old Aug 18, 2010 | 10:02 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
No disrespect, but doesn't anybody "search" anymore?
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
