will 2.8 oil pans fit 3.1?
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
iv only dealt with sbc in my 3rd gens, but i just picked up a 90 rs with a hacked up oil pan for $300. and its a 3.1 but there are alot of 2.8 engines at my local junkyards, and i just wanted to know if its a direct swap for 2.8 and 3.1 oil pans.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: will 2.8 oil pans fit 3.1?
no, but I know the two engines share almost every component. a 3.1 is nothing but a slightly bored out 2.8
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
yes they are the same...you could even use the one off a 3.4L in the 4th gens if you want
Engine: 383 hsr
perfect! thank you guys so much.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If you've replaced the oil pan on the SBC in a thirdgen, it's the same thing to replace the pan on a V6. You still have to lift the engine up to get the pan out.
If you're looking for a decent pan, check out Summit. You can get a new oil pan for cheap. I would have gotten mine there if I didn't find the one close to me for cheap on eBay. Also check there.
our support the clutch fund and buy my old 3.1 pan
yeah, I was going to post there is NO WAY it's worth it to go to a yard to pull a pan... WAY too much work for a part you should be able to buy for $20 from somebody here
mine is off a 92, its a little sludgy as i was trying to blow up the motor
but no rust or holes, just needs cleaned up and a gasket
but no rust or holes, just needs cleaned up and a gasket Thread Starter
Engine: 383 hsr
yeah it does sound like alot work to pull it from a junkyard. but idk how cheap i can get one from any of you guys. i saw one on ebay for $10 and like $15 shipping or sumthing. but i dont have an ebay account either lol.
but pilsbury live in my state. how much would you be willing to sell yours? cuz i could do pick up or something.
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
I would also recommend a high volume oil pump and trimming the windage tray to improve oil pressure and therefore circulation.
Engine: 383 hsr
alright sounds good. and thanks pillsbry i got the pan today
sweet glad its getting put to good use, i hate to let good parts go to the scrap yard
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
