Screaching noise
Old Sep 30, 2010 | 07:32 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
Screaching noise
Hey guys so today i start up my car nd theres a loud ear pearcing noise coming from the engine bay do you guys have any idea what this can be ? Thanks
Old Sep 30, 2010 | 08:51 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Screaching noise
That would be an engine gnome trying to eat your serpentine belt. You caught him in the middle of a meal and hurt him. Now you're doomed to engine trouble.
Old Sep 30, 2010 | 09:16 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
Thats not alot of help .. Does anyone have n idea of what this could be
Old Sep 30, 2010 | 09:45 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
"serpentine belt" It's in there, just disguised a smidge, its either the belt/s or a bearing on one of your accessories.
Old Sep 30, 2010 | 09:47 PM
Engine: 3.8, 3.4
oh and i think one of those engine gnomes ate one of my fusible links, and my fan relay switch harness wire
Old Sep 30, 2010 | 09:48 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
Haha .. how do I figure out what it is ?
Old Sep 30, 2010 | 09:52 PM
Engine: 3.8, 3.4
You replace the belt/s because its probably not been done as recently as it should have been done because people hate their cars and don't maintain them, but if you're tight on cash, pull the belt/s off, and turn your alternator pulley by hand, and your ac compressor by hand, and your tensioner(if you have a serpentine setup) and water pump pullies, if you hear metal grinding or other unpleasant noises it could be one of these accessories, and if a new belt doesn't fix it, then it IS an accessory and or accessory bearing.
Old Sep 30, 2010 | 09:53 PM
bl85c's Avatar
Car: '85 maro
Wet the belt before you start it and see if it goes away. Or take the belt off & start.
Old Sep 30, 2010 | 09:56 PM
Engine: 3.8, 3.4
taking it off wouldn't narrow it down...none of the accessories would be rotating, and I don't see it being the rotating assembly or crank pulley...
Old Sep 30, 2010 | 10:05 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
Could it be possible that when I put the underdirve pullies on I put a belt that is to tight ? I mean it was screaching a little but it got worse . And yes when I got this spray that supposed to get rid of the noise but it only does when I start the car nd spray it , then like twenty mins later it starts again nd doesn't go away unless sprayed again
Old Sep 30, 2010 | 10:10 PM
bl85c's Avatar
Car: '85 maro
Take the belt off and see if it stops. That spray goo doesn't do what it's supposed to throw it away. Just makes a mess.
Engine: 3.8, 3.4
Is it serpentine or multiple V-belts, and whens the last time the belt was replaced? And if serpentine does it use a tensioner?
But from what you just said, if I understand correctly you have a spray type stuff that is supposed to eliminate the noise, and does temporarily but then comes back, if thats so, you need a new belt.
Old Sep 30, 2010 | 10:12 PM
Engine: 3.8, 3.4
That won't accomplish anything....if he removes the belt/s, the only thing that will be rotating is the crank pulley, yeah it will stop the noise, but it won't narrow down the problem any and he certainly can't drive around without belt/s on.....really not sure why you're suggesting he remove it...
Old Sep 30, 2010 | 10:16 PM
bl85c's Avatar
Car: '85 maro
99% of the time when a car comes into my shop with an obnoxious squeal it's an ancient belt with too little tension or some liquid on it that shouldn't be. Start with the basics and progress.
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
its serpentine system and yes it does use a tensioner nd the belt was changed a year ago I can't see it going bad that fast
Old Sep 30, 2010 | 10:20 PM
bl85c's Avatar
Car: '85 maro
With the belt off spin the pulleys. Feel it out. Smooth? How much axial play do your idler/tensioner pulleys have?
Old Sep 30, 2010 | 10:22 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
I can't do that right now its kinda late nd dark out .. I will do that tommorrow nd let you know . How much play should it have ? If any at all
Old Sep 30, 2010 | 10:25 PM
bl85c's Avatar
Car: '85 maro
Barely any. A trashed bearing should be obvious. If not spray it with wd40 or oil it and see if that keeps the noise at bay 'till it dries up again. Then you have your awnser.
Old Oct 1, 2010 | 01:11 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
ok i took the belt off and spun the alt,tensioner pully and the pully directly under the alt. the on directly under the alternator sounds alittle off nd when ispin it, it makes a noise. i dont know what this pully is though or does. my engine is the 3.1liter
Old Oct 1, 2010 | 08:19 PM
bl85c's Avatar
Car: '85 maro
Do you have a smog pump?
Old Oct 1, 2010 | 08:21 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
Yes I do
Old Oct 1, 2010 | 08:22 PM
vertigo1202's Avatar
Engine: L98 TPI 5.7L 350
Transmission: 700R4 Automatic
I actually had this problem today, I heard a piercing screeching while driving, I have a v8 and i can barely here anything but my engine so i new i had to stop and check it out. when stopped i removed my air intake, turned the belt tensioner with a ratchet releasing the tension on the belt, took belt off the pullys, I noticed the small pulley attached to the belt tensioner was chromed by the rotation of the belt, I loosened the bolt on this pulley then rebolted it way tighter than before. It might have been loose because the noise stopped right away, its ironic because i just ordered a new tensioner today that should be in by 6pm at autozone. i ordered this after noticing the last couple days that my belt tensioner shakes alot ONLY when the AC is on. Today before the noise began i was driving with the AC on for about 2 hours, longer than most days. Maybe the belt tensioner shook so much it loosened its pully. regardless im replacing the whole tensioner as soon as i pick it up. hope this helps.
Old Oct 1, 2010 | 09:16 PM
bl85c's Avatar
Car: '85 maro
That would be your smog pump. Not uncommon for them to start making noise at this age. I've seen a few so worn they sieze. If emissions isn't a concern you can remove it and use a smaller belt. Look up the routing for a car without air injection.
Old Oct 1, 2010 | 09:33 PM
bl85c's Avatar
Car: '85 maro
Here's a quote from another site I thought was amusing.
A "smog pump" is a clever device that transfers available horsepower and converts it into a high pitched squealing sound. It also has the uncanny ability to soak up drops of power steering fluid and use them to self-destruct.
Old Oct 2, 2010 | 10:40 AM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
haha i needed that this morning i laughed pretty good, your right though, check belt, alternator(when bearings go bad in those they make all kinds of noise) and smog pump, youll find the answer and maybe even gain some horspower and weight reduction if its the smog pump
Old Oct 3, 2010 | 05:52 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
ok what do i gotta do to take the smog pump out of my car ? and will my car still run properly w.o it ?
Old Oct 3, 2010 | 06:28 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
ur sig is huge and annoying..just saying
Old Oct 3, 2010 | 07:39 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
anyone ?
Old Oct 3, 2010 | 07:50 PM
bl85c's Avatar
Car: '85 maro
I think I'll make the pic bigger. That way you can see all the dust on it.
You just unbolt the pump and plug the hole on the catcon. It will run just fine.
Old Oct 3, 2010 | 08:14 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
ok whats a catcon ? nd what about the pully thats on the pump?
Old Oct 3, 2010 | 08:18 PM
Engine: 3.8, 3.4
Catalytic converter, it has a bung on it for the smog pump, needs to be plugged with metal. From what he said, I think remove the whole pump, pulley and all? I know nothing about smog pumps, but thats what it sounds like he meant.
Old Oct 3, 2010 | 08:21 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
ya neither do i . thats y im trying to find out . isnt the smog pump connected to the engine block ?
bl85c's Avatar
Car: '85 maro
You can just unbolt it and the bracket from the motor. Use a belt for an earler car without air injection. Double check routing because its probably different.
Old Oct 3, 2010 | 08:24 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
well its a serantine system so id have to just buy a smaller belt bc i have underdrive pullies. where would i find the routing info on a car w.o air injection ?
Old Oct 3, 2010 | 08:33 PM
bl85c's Avatar
Car: '85 maro
Google, of course. Autozone's website has a free auto info application too.
Old Oct 3, 2010 | 08:34 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
i did just google it and nothing came up
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
