PERFORMANCE CHIPS HELP!! CAMARO
Old Oct 12, 2010 | 09:20 AM
86 Camaro joe's Avatar
Car: Camaro
Engine: 2.8 tune port
I have a 2.8l v6 camaro and every one
seems to want more power out of it ,
would a super chip help any at all or is it a waste ?
http://www.summitracing.com/parts/HYP-226021/
is one im looking at if
you recommend one let me know ,
Old Oct 12, 2010 | 03:19 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: PERFORMANCE CHIPS HELP!! CAMARO
It's a waste. Here's what you should be doing. Learning to tune is way more rewarding than any of the "power chips" out there.
Old Oct 12, 2010 | 03:26 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
^And probably cheaper.
I've got that chip (either that or the Jet stage 1. It's been a few years...). It didn't do anything but change some values at full throttle. I didn't notice a difference in town or on the highway. Might have been a change at WOT, but not $110 worth of difference....
Old Oct 12, 2010 | 04:30 PM
project89's Avatar
if u want the changes the chip will make for alot less just reset base timing to 12*
Old Oct 12, 2010 | 04:39 PM
bl85c's Avatar
Car: '85 maro
HA! Classic.
Old Oct 12, 2010 | 04:41 PM
project89's Avatar
Originally Posted by bl85c
HA! Classic.
lol its the truth pretty much,
the most those chips do is add a lil advance at wot and there was one other thing i just cant rember
edit
oh yeah remove the top speed limiter on the 3.1 cars / 2.8 cars dont have a top speed limiter
Old Oct 12, 2010 | 07:05 PM
Car: Camaro
yeaa i figured it wouldn't do to much ,
thanks,
Old May 9, 2012 | 03:23 PM
86cam2.8's Avatar
1986 camaro programming ecm ,v6 owners,take look
v6 0wners ,take look by b185c. new to programming swap ecm s10 blazer ect... i need most recent info? i have 1986 camaro 2.8 mpfi.look to up grade any advice besides whats in thread?
burners, moates. net? please help!
Old May 9, 2012 | 10:18 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 1986 camaro programming ecm ,v6 owners,take look
This is a old thread but hope this helps you a little.
Burn2 Chip programmer=This burns the chip
GP1 Package with 2 chips and adapter=this allows you to use a solderless chip removal and also these are the chips themselfs.
Both at Moates.com
ALDL 12 pin USB cable=this is the cable to datalog Via Laptop
At aldlcables.com
TunerPro RT version 5=the program to use for datalogging in real time.
At tunerpro.net
This is what I use personally although there are other items out there to tune the obd1 ecms with.
Old May 10, 2012 | 08:03 AM
86cam2.8's Avatar
ty eddie. car has 70 thousand and opened both ends. gets about 25 mpgs. have to baby to get it. will this program tell me exactly how too?or is there some info ican get from someone? dont want to damage car! lol. was thinking about using (2.8 v6/*165 scm (l)* bin ) to make driving more fun. how much horse power roughly do you think will get? will mpgs drop or gain?
Old May 10, 2012 | 08:17 AM
86cam2.8's Avatar
eddie can this burner be used to do other cars ecms> what other things can be done with this? about how much for all? how can i go about finding other ecms to do trucks vans ect..? i knew and this excitig!
Old May 10, 2012 | 06:22 PM
fasteddi's Avatar
Car: 1991 Camaro RS
It can be used on all Gm OBD1, I know that for sure but am not positive on what else it can use. It supports certain chips. In our case on thirdgens, 27SF512 chips are great and supported by Moates equiptment.
Upload you bin file your talking about if you want and i'll look to see if its whats correct for your car.
You would need a bin such that was your stock Bin file then you have to mod it as you wish after that. Honestly I love Speed Density ecm's (7730) much better and you have a MAF set up. Im still learning MAF when I can but Im not the best help in MAF tuning. So if you really need help post up a thread on the DIY-prom area for more info.
There is alot to be learned to get into this sticky and read up on 165 ecms if you want to do research https://www.thirdgen.org/forums/diy-...uide-book.html
Scroll down on that stick and look at the 165 info.
Old May 11, 2012 | 07:16 AM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Without changing ecms what would be the best way to eliminate the speed limiter?
I currently don't have access to a computer. I do almost everything via my Droid phone.
Old May 11, 2012 | 04:28 PM
project89's Avatar
toggle switch wired into the vss sensor, basically hen u hit 100mph u flip the toggle switch shutting down the vss sensor then u have no speedo and the ecm doesnt know how fast u are going. when ur done u flip the toggle back on and everything goes back to normal
Old May 12, 2012 | 08:00 AM
86cam2.8's Avatar
speed density ecm 7730? will be able to be tuned like the 165? is what is bought new?jy?same chipburner? easier to learn to do? a better uprade?
Old Jul 11, 2012 | 09:42 AM
Thanks, so what wire from the ecm is the vss?
I already have the torque converter lock-up by-pass switch done. I'd just put that switch next to it.
And if I'm ever pulled over and asked if I know how fast I was going? I can honestly say no.lmao.
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
