Pic Requests for 3.4L SEI engine swaps
Old Nov 15, 2010 | 04:26 AM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
I just bought a 3.4 out of a 93 that i'm going to rebuild and put in and i was looking for some pictures of people that have done the swap, along with any advice.
Old Nov 15, 2010 | 03:05 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Pic Requests for 3.4L SEI engine swaps
I did one in an s10.
Honeslty, the wiring efforts are not worth the work when your just upgrading from MPFI to SFI.
Old Nov 15, 2010 | 05:32 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
if your putting it in a camaro there are no wiring changes because you wont be using SFI, youll still be a MPFI
there are TONS of threads on this
https://www.thirdgen.org/swapboogie
https://www.thirdgen.org/forums/v6/v6...-3-4-swap.html (Dales 3.4 swap tech artical.)
https://www.thirdgen.org/forums/v6/2...3-1-3-4-a.html
a few to get you started
Old Nov 16, 2010 | 09:52 AM
Dale's Avatar
Engine: 350 S-TPI
by the title and my understanding of it, they wanted to swap the ecm/harness too?
Guess the original poster needs to verify which swap they are wanting to do.
Old Nov 17, 2010 | 05:09 AM
JackRs's Avatar
Car: 1991 Camaro RS
I dont want to swap the ecm if i dont have to. As far as the type of injection i can keep my mpfi?
Old Nov 17, 2010 | 07:04 PM
Pillsbry10's Avatar
you dont have to swap ecms
Old Nov 19, 2010 | 09:56 AM
Dale's Avatar
Engine: 350 S-TPI
Go to the middle link that pillsbry posted. That is almost a step by step of what you need to do.
Old Nov 19, 2010 | 08:57 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
The easiest swap uses MPFI, the swap involving SFI(sequential fuel injection, which btw resorts to multi-port fuel injection at high rpms because injectors can't keep up with the pulses) is a lot more involved, and not worth it it at all, besides, the 3.4 intake is inferior to the 2.8/3.1 intake, ironically...
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
