Speed Calculation help
Old Oct 22, 2000 | 10:25 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
ok Last ngiht me and my firnds were on the freeway and no one was around my firnd was like the fastest car ive ever been in was doin 110 so i was like wacth. Well i burried my speedo needle and got up to 6500 RPM i love having no govener. Well i did a speeed calcultion and it seems inpossible it sayd i was doin 179.67 MPH and i dono if i did anythign wrong but hers what i entered.
Tire radious 15
RPM 6500
REAR gear ratio 3.23
Tranny ratio 1
Did i do something wrong here????
Old Oct 22, 2000 | 10:44 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
check ur RPO codes..all v6's came with 3.42:1 i THINK it was 87+
88 Firebird 2.8
MODS (either coming or on):
Flowmaster Cat Back, Random Technologies Cat, 3" intermediate pipe, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6a, B&M Shifter, Transgo Shift Kit, Cold Air Induction, NEXT MOD: 5 speed...(torque convertor going so 5 speed a better idea) ..Then peeling and cracking paint..
Old Oct 22, 2000 | 10:52 PM
thought of one more thing...radius is 1/2 a circle...if 15 is the radius of ur tires..then the full diameter would be 30" which i KINDA DOUBT u have
take how large ur tires are then divide it in half and thats the radius..AND since u were in 4th gear doing that fast...look down the chart and enter the correct 4th gear ratio... its like .76 or something like that...
88 Firebird 2.8
Old Oct 23, 2000 | 01:59 AM
FAST RS's Avatar
ok my radius is 13 so i was doin 155.??? and my rear end is 3.23 i have my build sheet the stick came with the 3.42
Old Oct 23, 2000 | 11:58 AM
Vortex_89rs's Avatar
Remember that the calculations don't take several things into account: wind resistance, weight of the car, worn parts, and whether or not you actually have the HP to get your car up to that speed.
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Cragar Street Pro rims (old Series 30)
Pioneer DEH-P3000
1969 Camaro SC
350 HO from a Vette
Turbo 350 tranny
In the process of being restored
Old Oct 23, 2000 | 06:22 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
I think the speed might be a little high, i'd put you in the range of 130-135 maybe. 140'd be pushing it. unless you have major mods. you have to remember, the Z28's topped out at around the 140-150 mark, so when our 2.8's push 130-140 it's really good. Now, a new T/A can go until it reaches it's governer or 163, huh you call that a governer?
Old Oct 23, 2000 | 06:24 PM
85f-bird's Avatar
Engine: 2.8L, LS1
hey, by the way, what's your speedo go up to?
Old Oct 24, 2000 | 02:00 AM
FAST RS's Avatar
it goes up to 110 and i pinned it at the needle stop at the bottom and still kept goin faster i hit 6500 RPM.
I have
Power pullys
MSD 6al Blaster coil and msd wires
Flowmaster catback high flow cat
Fast Chip stage 2
TB bypass
Polished ports
cold air intake with a hudge *** K&n for a F$%# Rustang i did some other stuff but ive done soo much ive lasot count lets say 8,000 worth of repairs and mods u tend to loose track i put more money in the car then its worth but it was all worth it now i just need to blow my engine
Old Oct 24, 2000 | 09:29 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The highest I ever got was 137 mph, racing a VW turbo Passat. We both had CB radios on channel 19, and his speedo went up to 150, so I just asked how fast we were going when we were neck & neck. I remember being in overdrive, at low RPM's (love that B&M 4-3 kickdown valve!), but I don't remember the RPM's. Around 3000 I guess?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Elephantismo
Feb 13, 2019 12:51 AM
PurelyPMD
May 5, 2016 04:57 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
Giocio
Oct 1, 2015 12:20 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
