Car not staying on!!! Please all read!
Old Oct 14, 2000 | 04:41 PM
Garmer's Avatar
Almost ever single time I come to a stop my car dies, but it is fine going at a speed over 25! I think the idiling is off. I installed my Fastchip 2, recently and now it idles alot lower now, could this be the problem?? All answers are welcomed!!!
91 RS Camaro
3.1L
Cat Back System, K&N filter,modified air box, Fastchip Stage 2, 160 thermo, Rapidfires and Bosch Wires, soon to come: Homemade Ram Air,and maybe power pulleys, 5 Air Horns
Old Oct 14, 2000 | 05:44 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Is the SES light coming on, if it is what code??
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
Old Oct 14, 2000 | 05:50 PM
Garmer's Avatar
No the whole dash just goes blank, and it only happens when in drive, it wont do that when it is in park!
91 RS Camaro
3.1L
Old Oct 14, 2000 | 07:21 PM
Kevin S's Avatar
If you can't find anything wrong,raise the idle up some.
When in park,what do the rpm's read at idle?And what did it read with your old chip?
If they are the same,raising the idle isn't a good idea.
Check your TPS....that could cause it also.
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
[This message has been edited by Kevin S (edited October 14, 2000).]
Old Oct 14, 2000 | 07:24 PM
Garmer's Avatar
Kevin, before the chip it idle at 1250, now it idles at 750!
91 RS Camaro
3.1L
Old Oct 14, 2000 | 10:13 PM
Kevin S's Avatar
What does it read in drive?
1250rpm's is kinda high don't ya think?
You probably could get away with just raising the idle.But have the TPS checked first.
http://v6fbody.com/
http://clubs.yahoo.com/clubs/tristatecamaro
Old Oct 15, 2000 | 08:25 AM
Garmer's Avatar
I thought it was high, too. Right now in drive the idles bounces around and will soon or later just die.
91 RS Camaro
3.1L
Old Oct 15, 2000 | 12:27 PM
Monkie's Avatar
Thats what mine idles at, around 1000 to 1500 somwhere in that range. All I know to tell you so the car doesnt stall on you to when you're at a red light put it in park or neutral and rev until the light turns green. Im sure that would work. Good luck man, sorry I cant help ya more.
Old Oct 16, 2000 | 12:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Garmer, it dies when you slow to a stop? Could be the Mass Air Flow sensor, either that, or your IAC passageway might need to be cleaned out of carbon.
Kevin's got a good idea on the TPS, too- When my car's warmed up, it idles around 600-700 RPM in drive, 800 just sitting around.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 16, 2000 | 03:21 PM
Garmer's Avatar
The car is going in tomorrow(w/ other little things that need to be done!) I happen to think that the chip did something. I mean before when I had the regular chip it never died, then when i put the Fastchip in it started to die. The only thing that shows up different is that the car idles lower now (about 500 RPM). So that is why I think the idling is to blame. Me and my dad did idle it up this weekend up like a 100, and it didnt die, but I can still feal that it almost dies each time!
91 RS Camaro
3.1L
Old Oct 16, 2000 | 03:23 PM
Garmer's Avatar
Oh and how do you adjust the TPS?
Old Oct 17, 2000 | 12:19 PM
89 bird's Avatar
my car is doing the same thing. sometimes it shuts down when i come to a stop. my only solution so far is to rev it when it feels like it is going to die.
Old Oct 22, 2000 | 06:46 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
one thing, go to a mechanic shop to check!
I had the same thing 2 years ago and after a while my crankshaft died (stuck)needed a new block. The mechanic said I had to come in before, so there was a chance to save some.
Horst
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax muffler
Old Oct 22, 2000 | 09:32 PM
KNTRDR's Avatar
I HAVE A SIMULAR ISSUE WITH MINE. I HAVE REPLACED TPS, MAS AIR FLOW, O2, COOLANT TEMP, PLUGS, WIRES, CAP AND IT GOT BETTER. I AM LEANING TOWARDS A VACUUM ISSUE AT THIS POINT. I UNDERSTAND HOW YOU FEEL, IT IS VERY FRUSTRATING. GOOD LUCK AND LET US KNOW HOW IT WORKS OUT
Old Oct 24, 2000 | 03:33 PM
Garmer's Avatar
I got the car back yesterday, and the idling was the problem. They turned it up and now it doesnt shut off anymore. Thanks to everyone that posted!
91 RS Camaro
3.1L
Old Oct 25, 2000 | 03:09 PM
Garmer's Avatar
You guys wont believe it, the car died on me again! This time the SES light came on! How do I check for codes?? Any more suggestions? I think i will take it to the shop again, to see what they think.
91 RS Camaro
3.1L
Old Oct 25, 2000 | 04:40 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Check the FAQS.
Old Oct 27, 2000 | 03:50 PM
Garmer's Avatar
OK, I am getting code 12, over and over, if I am correct that means that nothing is wrong, right?
91 RS Camaro
3.1L
Old Oct 30, 2000 | 12:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Correct. Garmer, when the car stalled, did the SES light come on -before- the car stalled? Because when the engine's not running (stalled) the SES light -should- be on; that's normal. But if the SES light pops on when the car's running, that means there was an error.
Did you see my message up above about cleaning out the IAC passageway?
Old Oct 30, 2000 | 05:49 PM
Garmer's Avatar
Tom,
The SES light only came on when the car shut off. I was talking to Ed Wright and he said that the chip should not had done that and I am sending it back for a new one. By the way how do you clean out the IAC passageway and adjust the TPS? Sorry I dont know how to do these, but hey I am learning!
91 RS Camaro
3.1L
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
novaderrik
Aug 10, 2015 12:44 PM
Kaweh
Aug 9, 2015 02:54 PM
