Couple of Problems
Old Oct 26, 2000 | 09:11 PM
CamaroVroom's Avatar
Couple of Problems
Ok i have an 88RS (2.8L) ok 1st prboblem...My car heats up real quick around town!!Why is that. On the highway i get a lot of air there cuz i am cruisin but around town its up quick and after awhile when it gets hott and say i go home for supper or whatever if i take it out again BOOM it stalls at like a stop when i try to get outta my street..2nd My car DRINKS antifreeze like it's an alcoholic.. There is no SES light either i checked and all that.... help me out yet again
Old Oct 26, 2000 | 09:53 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
when you say the car gets how real quick, do you mean that it's getting over to the red area on the temperature guage, or is it at the normal operating temp, of about 195*? If it's going past normal op, temperature then you might have aproblem with the thermostat, i just replaced my thermo, when i got the new motor, but it still runs up to about 200* and then starts to cool off again. Also, have you noticed any antifreeze on the ground, i've never noticed that my car was having trouble with anti freeze, you might have a leak somewhere, if your motors dirty clean it off with degreaser, and then check to make sure there aren't any leaks, (green stuff) on the motor, after a ride.
Old Oct 26, 2000 | 10:07 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Ask this on the Tech Board.
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
[This message has been edited by IROCZTWENTYGR8 (edited October 26, 2000).]
Old Oct 26, 2000 | 11:41 PM
3.1 firebird's Avatar
try checking for leaks and check and make sure the water/antifreeze mixture is correct. Also check your timing? and check the thermostat. TomP.... Engine Boy?
Old Oct 26, 2000 | 11:43 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
see my reply to "STALLING??"
Old Oct 27, 2000 | 12:53 PM
Garmer's Avatar
Voom,
My car used to do that. 1st question, my car used to run real hot,, when I bought my Fastchip-2, i got a 160 stat. The car used to run about 225, now it doesnt even get up to 200 (city). 2nd check your hoses, I was losing a lot of antifreeze too, in turned out just my hose clamp wasnt tight enough. Hope thats helps!
91 RS Camaro
3.1L
Cat Back System, K&N filter,modified air box, Fastchip Stage 2, 160 thermo, Rapidfires and Bosch Wires, soon to come: Homemade Ram Air,and maybe power pulleys, 5 Air Horns
Old Oct 27, 2000 | 02:55 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
I had the same prop. coolant went thru the headgasket into the oil, did you check this?
No coolant or less coolant is no circulation
and the motor gets hot. The coolant goes thru the exhaust system.
Old Oct 30, 2000 | 10:23 AM
More news on my problems... Ok i was at work and someone came in and told me that there was antifreeze all over the ground so i literally ran out there and took it to the closest body shop and they said that it was a bad lower radiator hose..So they replaced it and i just got it back yesterday so i have to fill it up with antifreeze and see if thats the trick...He also said to replace the thermostat in the future.
Old Oct 30, 2000 | 05:36 PM
Garmer's Avatar
Vroom, I had the same thing happen to me, if you dont live in a very cold climate, get a 160 stat!
91 RS Camaro
3.1L
Old Oct 30, 2000 | 08:07 PM
Brian K's Avatar
My fan did not always kick on and I had a similar prob... Try juming the a wire from the ignition wire to the fan and let it run when ever the car is on. See what temp ya are runnin there..
Consider watter wetter and a new thermo with small holes drilled on the side to let air by...
Cleotiz
Jan 6, 2018 08:56 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
