iroc cluster?
Old Oct 13, 2000 | 01:18 AM
skittlz's Avatar
iroc cluster?
i've got an iroc cluster with the 150 mph speedo, that i was thinking about puttin in my car but i herad there are problems with v8 clusters in 6's if anyone knows anything about this or has don it let me know thanks.
Old Oct 13, 2000 | 09:11 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
I installed an IROC cluster in my 84 Camaro. The only thing I had to change was my sending units b/c I went from warning lights to guages. If you have to change sending units pay attention to your oil presure guage b/c they make a couple different types, depending on how high your guage reads (I beleive the two types are 60 & 80)
Below is a link to a tech article on how to do the swap: https://www.thirdgen.org/newdesign/tech/gauges.shtml
If you have any other questions feel free to ask.
"5 out of 4 people have a problem with fractions"
My Camaro: http://home.earthlink.net/~singleton052095
Old Oct 13, 2000 | 09:38 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's one more thing... a v8 tachometer expects 8 pulses for an engine revolution. Your v6 will just send 6. That means your tachometer will be 25% slow. That equation is simply 1.00 - (6 divided by 8).
Good reason to install an aftermarket tach!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 13, 2000 | 03:24 PM
will0325's Avatar
i put IROc gauges on my car, i have an 86' 2.8, all i had to change is the oil pressure switch to a sender, just one thing, don't get a sender for a v-6 w/gauges, get one for a 350 w/gauges, for some reason when i got the one for the 6 it buried the oil press. gauge, other than that it is a driect drop in and work, i love it, and it looks alot better than dummy lights, and no longer a gas gauge the size of ur speedo.
Old Oct 13, 2000 | 10:43 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Tom's right!! NOBODY around here believed me when I told them that, but it's true.
My friend and I put an '89 RS 305 cluster in his '86 2.8, and I told him the tach would be off. The oil pressure was off the chart, and the tach was about 250 RPM slow at 45MPH. How did I know?? We put his car in 4th and mine in 3rd (same ratios, as I have an auto and him a 5 speed), and mine read 2250 exactly and his was 2000. Like Tom said, it expects 8 pulses and his only getting 6.
To solve the problem, throw a 6 cylinder tach in the V8 cluster, and you're good to go
Jason E
'89 Camaro RS 2.8
Grey/AT/T-tops/all power
Hypertech chip/2 K&N filters/Accel 8.8 wires/RapidFires
Eclipse CD and 100x4 amp/Boston 746 4x6 plates and RX 6x9 3 ways/ALL Monster's goodies
Alpine Alarm w/ Keyless entry
IROC tailights/t-windows
Old Oct 16, 2000 | 12:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Jason, thanks for the "proof"! I didn't know the V6 tach just drops in, either. Could it be replaced with, say, an Autometer in-dash one?
Old Oct 17, 2000 | 09:16 PM
Jason E's Avatar
Honestly Tom, I'm not sure. I've never tried to put an aftermarket tach in a stock cluster. Hehe...the only time I did a tach was in my old winter beater, an '87 Skyhawk!!!! I had the only one around with an autometer voltmeter, oil prsssure and engine temp gauges
But yeah, a factory V6 tach will drop in a V8 cluster....I'm gonna add an IROC cliuster to mine, and all I gotta do is swap tachs. Whats nice is the only other gauge that will be off (oil prsssure) is part of the tach anyways!!
Old Oct 20, 2000 | 06:48 PM
RiceEater's Avatar
I am doing a swap with my firebird. Will the speedo and gas gauge read accurate? I am switching from an 85mph to 140mph.
1986 Firebird
2.8l V6 MPFI
Cold Air Intake
K&N Filters
<html><a href="http://www.geocities.com/inhumation1/cambird.html">This site has nothing to do with the KKK, it just has a bad name</a></html>
Old Oct 20, 2000 | 09:49 PM
Jason E's Avatar
Both SHOULD be accurate...assuming they were accurate in the 1st place!!
The best thing to do is, before you change it, have someone follow you and measure the speedometer variation between the cars. Then, pop the new speedometer in, and use the same car to measure the variation. This will tell you if, at all, the 140MPH speedometer is off of the 85MPH one.
Old Nov 1, 2000 | 06:20 AM
NvrRobX's Avatar
I have a 92 RS V6 - one question about going to the 150 mph speedo - Do I need to change out any sending units or anything?
Old Nov 1, 2000 | 08:54 AM
Jason E's Avatar
If you only change the speedometer (I don't even know if you can do that with '90-'92 clusters), no you don't have to. If you're going with an entire Z28 cluster, then you'll have to change the sending units for the temp gague and your tach...the tach won't be accurate, and neither will the integral oil pressure gague.
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
mustangman65_79
Aug 11, 2015 03:17 PM
