replacing all the vacum lines?
Old Feb 13, 2011 | 07:11 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Does anyone know where i can get all the vacum lines under the hood replaced? im thinking about going to a shop and having them mess with it all but if its easy to do i might see where i can get the lines at and do it myself.
Old Feb 13, 2011 | 08:15 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: replacing all the vacum lines?
all you need to do is go to parts store and get rubber hose and replace them one at a time so you remember where they all go. its not that hard really
if you have any of the hard plastic lines you can replace them with rubber too
Old Feb 13, 2011 | 08:26 PM
Engine: L31 350
what about the hose for the charcol canister? thats the main one i know is leaking, then i have another cause after i drive for a few minutes my check engine light comes on due to a vac leak
Old Feb 13, 2011 | 08:40 PM
Pillsbry10's Avatar
on mine its just a rubber line as well..yours could be diffrent though since mine is a 92
Old Feb 13, 2011 | 09:19 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Replacing the lines yourself will cost you about $20 and maybe two hours if you get lost. A shop will want WAY more than that. There WAS a sticker under your hood (the old one if it's the one that was on the car when you bought it) that has a diagram telling you what goes where (hence, vacuum diagram).
Old Feb 14, 2011 | 09:20 AM
Engine: L31 350
the car didnt have the original hood when i got it, it had a fiberglass z28 hood on it which i replaced with my iroc, where can i get the lines at? also can anyone point me to an online diagram?
Old Feb 14, 2011 | 10:41 AM
Engine: 2.7L V6
Axle/Gears: 4.41
my posts... I've posted a link to a pic of mine at least a dozen times since Thanksgiving.
Old Feb 14, 2011 | 07:12 PM
Engine: L31 350
will do dan
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
