easily confused, spark plug help?
Old Feb 25, 2011 | 12:10 PM
DaKrames92's Avatar
Car: 1992 Firebird
Engine: 3.1l
Hey, so a combination of my dad and the manual confused the hell out of me. Just a quick question, is this how the spark plugs should be wired? Obviously not straight over the intake manifold, but to each cylinder.
Thanks!
Old Feb 25, 2011 | 12:12 PM
84CAMARO28inFL's Avatar
Re: easily confused, spark plug help?
Ive a different question and i wont start a new thread about it .. What IS the best plug for the 2.8L V6?
Im getting 8mm wires, and probably new distributor and parts for STRONG SPARK !!! .. Plugs? Name/model/type, thanks. And model #.
Old Feb 25, 2011 | 12:33 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
That's the plugs should go in, as for 84CAMARO's question the stock ac delco plugs will do just fine.
Old Feb 25, 2011 | 12:36 PM
herbz28's Avatar
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
if you do a 84CAMARO28inFL there are tons of threads about spark plugs that topic has been discussed many times i just run the stock plugs in my car and they do just fine
Old Feb 25, 2011 | 01:17 PM
DaKrames92's Avatar
Car: 1992 Firebird
Engine: 3.1l
cool! so I was right? haha my 3.1 thanks you!
Old Feb 25, 2011 | 02:12 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
AC delcos are the best plugs for our engines.
Old Feb 25, 2011 | 05:33 PM
AC Delco recommended three times? I will get the "Normal" AC Delco plug. NON-Platinum, id imagine. Also 8MM wires, maybe strengthen up that spark a bit w "new" dist/cap? I had a car that had a CRACKED dist.. and made the car run like many things were wrong.
hEAT RANGE? :d
Old Feb 25, 2011 | 05:43 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Does your car still have the emissions label? It should have the exact plug number printed on it. As for heat range, unless you have a problem with oil(white chaulky deposits) on plugs, stay with the recommended plug#. If you do have an issue with oil deposits, short of overhaquling the motor, you can move up one heat range. Be aware, you may run into detonation and/or fail smog test for high NOX if you go too hot.
Cornholio7979
Sep 20, 2018 02:31 AM
evilstuie
Feb 28, 2016 03:33 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
