Unwanted cruise control!!!
Old Feb 18, 2001 | 02:46 PM
MR. JORDAN's Avatar
I can't figure it out? As I apply some throtle,It sticks on me.The only way to make it stop is to press the brake pedal?? What's up with Dat! Has this happened to anyone??
Oh yeah! My car is in the sig...86 = 2.8L
Thanks!!
[This message has been edited by MR. JORDAN (edited February 18, 2001).]
Old Feb 18, 2001 | 05:19 PM
KED85's Avatar
Start looking for vacuum hoses and broken/kinked cable lines.
Binding along the way, too.
FIX IT NOW!
Before you hurt yourself or someone else.
Uncontrolled acceleration is NOT FUN!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Feb 18, 2001 | 05:56 PM
MR. JORDAN's Avatar
It's like there's a switch in the brake pedal? As soon as I tap it, the RPM's drop!
Perhaps Electrical??
Old Feb 18, 2001 | 07:35 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
When you hit the brake even the slightst it will disenguage the cruse control.
Old Feb 18, 2001 | 09:12 PM
25th anniversarry RS's Avatar
If the switch is off on the CC it shouldnt do that, check to make sure the connection in the switch is workine properly
Old Feb 19, 2001 | 02:14 AM
MR. JORDAN's Avatar
That's the thing! I don't have cruise control on this car..
Here's an example. I can cruise up to 60kp/h, and when I take my foot off the gas pedal,The car will remain traveling at that speed.Just like if the car had CC and as soon as I just tap the brake pedal the RPM's drop.
Another is. When I;m in park,and I press the throtle to 2000rpm. The RPM's remain at 2000 until i touch the brake pedal. WTF!!
I hope this explains my problem a little better. I just hope it's not serious..
WTF is causing this to happen?? Thanks again!!
Old Feb 19, 2001 | 08:31 AM
87CamaroLT's Avatar
I would say sticking throttle cable, but it wouldn't change when you hit the brakes.... If you had cruise control, that would definitely be the cause of it.... hmmmm.... Tom? Tom! Help this guy....
--'87 Camaro LT --
Currently undergoing a 2.8->3.4 swap.....
Old Feb 19, 2001 | 12:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's a shot in the dark- is the floor mat up too high? I've had that happen to me twice lately... the floor mat keeps the accelrator pressed up. In my cases, I've had to pull the floormat back, because tapping the brake didn't slow anythign down.
But maybe when you tap the brake, you're moving the floormat down enough to un-bind the gas pedal? Maybe? It's a stretch... but I can't think of anything else that the brake pedal would affect.
The brake switch only controls the brake lights, torque convertor clutch disengagement (for an automatic), or a cruise control.
There's the possibility that it might be vacuum related... when you hit the brake, the booster sucks some vacuum out of the engine- but I'd imagine if that were the case, when you'd let up on the brake, the rpm's would go back up.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 19, 2001 | 01:43 PM
MR. JORDAN's Avatar
Shall Investigate! Thank you!
Old Feb 19, 2001 | 09:27 PM
1984-Firebird-SC's Avatar
Car: 2002 Grand Am GT
Engine: 3400 V6
Transmission: Automatic
That's one odd problem Jordan...
If I knew the first thing about how a car worked, I'd give my 2 cents, but I'm pretty useless at this tech stuff Good luck with it!
Old Feb 21, 2001 | 09:53 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
If you bought the car used could it be a possibilty that someone had to switch the turn signal indicator (That is where the CC switch is on my Camaro) and put one on w/o the cc switch causing the cc to be engaged?
Just a thought
"5 out of 4 people have a problem with fractions"
My Camaro: http://home.earthlink.net/~singleton052095
Old Feb 22, 2001 | 09:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
So... what's the deal with this problem?
[edit] I mean as in "is it still a problem"?
[This message has been edited by TomP (edited February 22, 2001).]
Old Feb 24, 2001 | 07:04 AM
MR. JORDAN's Avatar
For the love of god!! A chunk of underlay was keeping the gas pedal pressed down ever so slightly. And when i would press the brake, The under lay would move and relese the gas! Can you say MORON! Sorry to waste your time.However, thanks for the help!
Old Feb 24, 2001 | 11:39 AM
KED85's Avatar
Hey, be thankful, now, you found it, instead it kept being a problem, as you were skidding on black ice
You were smart to ask someone.
Chat Soon,
KED85
Karl
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
