my 2.8 dies
Old Mar 27, 2001 | 12:46 PM
82birdman's Avatar
my 2.8 dies
whenever i come on to the gas the car responds very well and then it dies for a second then continues to pick up speed. I don't have a tach so I can't tell you when it does it but it is under 10 mph. any suggestions
Old Mar 27, 2001 | 01:06 PM
Ovrclck350's Avatar
Could it be that you're in 2nd and it shifts down to first to accel?
Old Mar 27, 2001 | 01:17 PM
82birdman's Avatar
no the car is a 4 spd and it is in first.
Old Mar 27, 2001 | 01:20 PM
82birdman's Avatar
BTW could it be as simple as a gas filter, pump or may be a dirty carb. ???
Old Mar 27, 2001 | 03:03 PM
sgtpanther's Avatar
does it want to die at idle? If so it might be your O2 sensor..that is what mine did
Sgt Panther
89 Firebird..2.8/3.4 conversion
Old Mar 27, 2001 | 03:18 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
When was the last time the carb was cleaned out?
Any other details?
Any other noises to accompany the dying out?
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old Mar 27, 2001 | 03:29 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Yes, it could be simple.. possibly fuel filter, easily the pump, and easily in need of carb cleaning. I seriously doubt the O2 sensor would have anything to do with it since to my knowledge 82-84 2.8's weren't equipped with them =P
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers, possible performance chip I don't know about.. gotta crack open the ECM and check sometime
Old Mar 27, 2001 | 06:16 PM
87RS402's Avatar
It's the accelerator pump. No big deal really. If your hurting for $ right now you can just change the diaphram. You should rebuild the carb if things are starting to go wrong. The rebuild kit should be around $20. The kit will ahve everything you need and most have instructions as well. If you can, put towels down and do it on the kitchen/dining room table.
Old Mar 29, 2001 | 12:42 PM
82birdman's Avatar
I took it in to get looked at basic carb cleaning but the problem is a miss in one possibly two cylinders (I didn't really notice it myself because of a small gap in the manifold and lack of automotive knowledge )which means I have a place to start from ie plug, wires, cap. But thanks for the sugestions it is great to know that if i do have a problem there is a place i can go to for help
Gunner242
Dec 25, 2015 04:49 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
usafirebird
Sep 29, 2015 11:58 PM
